Question about Technics SL-BD20D Turntable
Garrard 210 underside pics/drawings
Have a garrard 210 record changer that i want relived. Need pics and/or drawings of the underside. I'd like to know where to put some detached springs and check if parts are missing.
Also, its running a little bit fast (40 rpm) and there's still rumble after some oiling.
Thnx in advance
Bobby
  • gesel May 02, 2009
    garrad 210 i─čnesi nerede bulabilirim
I have a Denon D-F10 component system and I have bought a Garrard SP Mk 3 record player which is the best cartridge to use in the Garrard for this system?
All depends on how young you are and just how good your hearing is. If you have hearing issues or are aged and have a high frequency rolloff (normal for age) there is no point in paying megabucks for what you cannot hear. Just be pragmatic and get a cartridge that sounds good to you and is gentle with your records because it has high compliance and tracks at low tracking forces. Shure M91ED is a great cartridge and still available if you get lucky.
Aug 30, 2017 | Denon Audio Players & Recorders
Garrard SL95 turntable does not stay running
It might be old or something's probably wrong with it, it might need to be repaired by a professional or a manufacturer that owns the product.
May 12, 2017 | Audio Players & Recorders
What needle do I need for Garrard turntable model 3250? My needle is missing because of my son discarding it.
If you look at the cartridge it fits into. Then you will see a model type and number. Enter that into Google and the stylus will also turn up.
Feb 11, 2017 | Audio Players & Recorders
How do you save pics from emails to your gallery
Hi,its pretty easy.All you have to do is open the email and draw your courser towards the picture and it will have an arrow pointing down.Ill recorded a video and show you.And if its your phone just hold ur finger on the pic and and select SAVE.Then go to downloads and check it.
Jul 17, 2014 | Blu Cell Phones
I have a garrard turntable and I'm trying to hook
Connect the turntable wires into the recievers phono input and you should be good to go
May 16, 2011 | Technics SA-EX110 Receiver
I inherited a Garrard Synchro-lab 72B that I want to use to play 78 rpm records. I also bought a Shure M78S cartridge with the required 2.5-mil stylus. however when I started to work on replacing the...
Sometimes you have to invert a changer and place on padded supports to get access to cartridge. Be sure to identify wire connections to the old cartridge before removal and keep track of cartridge mounting hardware so it doesn't get lost.
Music plays normally at first then begins to cut out. The problem gets worse as the CD continues to play. RCA RP8070 Five Disc Changer. THANKS
There is a problem with the laser pic-up assembly(eye) 1st,2nd, 3rd,4rth music/track are recorded on disc from the center to edge.As the laser moves toward the edge the laser can't read perfectly the stored data on the disc. possible cause:the disc is in figure of 8, the lens needs cleaning, the suspension of the laser assembly,poor recording speed,spindle motor and voltage fluctuation of VCC
Sep 01, 2009 | RCA RP8070 5-Disc CD Changer
My console can only play 45 rpm records
There should be a record size selector switch somewhere. It will move the arm to the positions for 12inch 7inch and 10inch records. It must be set to 7inch or 10 at the moment. For 33 it should be on '12' and for 45 on '7'.
Jul 11, 2009 | Audio Players & Recorders
My olympus Fe-210 wont record sound
This isn't a problem, the Fe-210 doesn't record audio and it was built this way.
Nov 05, 2007 | Olympus FE-210 Digital Camera
Technics SL-BD20D Turntable Logo
414 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
