Question about Whirlpool Washing Machines
Not spinning the mod lxr7244jq1 yype 107 after it finishes rinsing it just stops there i had to take the blakets out and take the washer out to drain it to drain it i just put the drain hose down on ground
I changed the safety switch under lid works fine now thanks.
Posted on Apr 13, 2009
Kenmore 80 series Model # 110.23832100\r\nthe washer fills up agitates, when finished washing it stops pauses a while then starts to spin, you can hear the water going out put it is like it can't pick up...
Hi
If the washer is not draining then it is due to a clogged drain pump, drain filter or a kinked drain hose. Clean the drain hose, inspect if the drain hose is plugged. Also check the connection to the drain pump and make sure wiring is fine. Check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Apr 07, 2011 | Kenmore Washing Machines
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
I have a Whirlpool washer, Serial #CL1510429, mOD #LXR7133JQ1, Type 107. The washer stops right after washing. Water will not drain nor will it spin. What is the problem?
3949247 - LID SWITCH *** is probably bad. these units only look for that lid switch circuit to be closed at the end of the wash cycle and end of the rinse cycle, prior to spin/pump out. its a safety switch so the unit shuts off when you open the top.
you can go to several sites and find parts blow ups so you can find how to access that switch thats below the top.. hint: the top, front, and both sides come off as a unit to gain access to the components below, leaving the chassis sitting upon the floor.
best of luck,
ttfn
Oct 24, 2009 | Whirlpool Washing Machines
Awful noise won't rinse wash or spin, on my whirlpool washer
http://www.youtube.com/watch?v=WLPGs2UMUJc
This video will show how to replace the direct drive coupling that runs the transmission.
Jul 05, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
More than likely motor has lost a stage in it. I would replace it.
Jun 29, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Washer won't drain or spin out the water
i pulled the motor out od the bottom and pulled a baby sock out of the gear in the balis tank
Aug 21, 2008 | Washing Machines
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
238 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
