Question about Acer Aspire 5100 Notebook
I have an Acer mini laptop. My screen will not come on.
When I push the power on button, I hear the motor coming on, but my screen doesn't come on.
  • Anonymous Apr 14, 2009
    They tell me with mine it is the motherboard - and Acer says they do not have parts for this "old" (1996) computer any more
  • rpcimino May 11, 2010
    Can you connect an external monitor to the laptop?
Laptop wont start.
Remove the battery and unplug the power cord for 5 minutes, put in the either the battery or the powercord and power on.
if it doesn't power on, make sure the charging light is lit on the front of the laptop when the power adapter is inserted and plugged in properly.
light blinking when you power on means battery low / no power.
If the problem doesn't go away you need to contact acer for warranty service if you are outside warranty contact a local repairer.
Jul 20, 2012 | Acer Extensa 5420-5687 Notebook
Acer extensa 4420 shuts down right after you push power button
sounds like it doesn't have enough power, is it completely charged? you may want to make sure you're getting power from the charger itself.
Jul 02, 2012 | Acer Computers & Internet
Acer extensa 4620 z will not power on have a new ac adapter and power cord . i can charge battery and charge battery light comes on but push power button and nothing
Try the following, one at a time.
- Remove battery then connect power cord, then power on
- Remove the memory modules then power on
- Remove the other optical drives, then power on
- Remove other components, then power on.
This process is to illiminate the faulty component. It is possible that one component is faulty and is causing shortage that's why your laptop won't power.
If this doesn't work then you need to remove the internal components like hdd.
Hope it helps.
May 08, 2011 | Acer Computers & Internet
Dell inspiron mini -- at first it works fast but suddenly the screen goes black and I don't know why. I tried pushing the power button but it didn't work, the power button still lights up (so meaning, it...
Hi, Please try removing the battery and then starting it. Those beeps are error codes that help tech support people identify the problem, The easiest solution is to take the laptop to service center. Good Luck
Apr 01, 2011 | Dell Inspiron Mini 10 Notebook
My Acer laptop won't work
The power supply needs to be checked.
Jul 06, 2009 | Computers & Internet
It will not come on. It shows in the mini screen
sir i want to download free soun driver for compaq c500 lapop
Apr 11, 2009 | Compaq Presario PCCOM2232US Notebook
The screen on my Acer Extenda 5610 is blank
I had the same problem with a vaio, it was the memory card.
I removed one (bad) card and it worked fine.
I hope this helps :)
Feb 23, 2009 | Acer Aspire 5610-4648 Notebook
Toshiba satellite m40x
Do you hear the fan come on? Do you hear the hard drive spin up or notice the hard drive light come on? I relaize it may be a short spurt.
Jan 06, 2008 | Toshiba Satellite A100-S8111TD Notebook
Acer Aspire 5100 Notebook Logo
278 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
