Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Blowing Bulbs in the 50WE655
I recently replaced the bulb, which blew almost instantly. I thought it was only the bulb and then learned of the ballast. The ballast was replaced by a tech and another bulb installed less than 20 days ago. Now, this bulb shot. I bought the bulbs and ballast on ebay, but my tech thinks it's the bulb (he said it may be a "B" line). It's made by LTI (Lighting Technologies Int.) in CA. I spoke to the company rep and she says some bulbs must be the OEM part. Now I don't know if it is the ballast or the bulb! Any help? would be appreciated.
  • HLKing Sep 18, 2007
    I've added an extra fan behind the unit and for 7 days (more than the last bulb) it is still bright and working. What is your response
  • HLKing Sep 20, 2007
    Thank you! Now 9 days and still going. I'll take your advise and contact Sony.
    Sergeant:
    Champion:
  • 375 Answers
Must replace with original bulb by sony,others don't last,ask for a refund from the lti company or a replacement if they say different at no cost to you.
Posted on Sep 10, 2007
  • g w Sep 18, 2007
    if it works go for it,i'd contact sony and ask why the internal fans arn't enough to cool the engine ,i never had that happen before.
SOURCE:
I installed higher amp bulbs,and my fuse blow out almost instantly,now my dashboard lights and Guage not working any more,any thoughts?
fuses are there to protect the circuit
putting in bulbs that required a bigger current draw that what the circuit was designed for will blow the bulbs
most bulb sockets will only fit the correct wattage bulbs so by fitting higher wattage bulbs there could have been a dead short
circuit boards are only very thing copper so the time taken if heating a fuse to fail point ( blowing the fuse) could have melted a section of the printed circuit causing the rest of your problems
Nov 29, 2016 | Cars & Trucks
My 01 grande Cherokee keeps blowing brake
the bulbs you mean, not the BRAKE FUSES?????
blows what.
if the lamps blow, they are the wrong lamps
or the alternator regulator has gone berserk and the line voltage , is over 15vdc.
my guess is bulbs.
and would be system over voltage.
i had one car in 1984 that the reg went nuts and blew out all bulbs in the, car at 2am. (and not a nice part of town either,,,,)
up upgraded that car to electronic reg. ,
like i do all my classic cars now.
buy a cheap 10 buck DMM volt meter at walfart.
and put it across battery terms, running and racing idle.
13.3 to 15vdc is legal range.
Sep 27, 2014 | 2001 Jeep Grand Cherokee
Bulbs keep blowing
You may be touching the bulb (ampule) and leaving a fingerprint on it which creats a hot spot and blows the bulbs up prematurely.
Mar 25, 2013 | Mitsubishi WD-65731 65" HDTV
The light blew on my Beaumatic F60 extractor fan, thought the bulbs had gone so changed the bulbs, they lasted a couple of minutes before blowing again and then the fan wouldn't work also. I can't find a...
Look at the instruction/installation manual.
Are the bulbs 12volts or 120vac? If it is 12v there is a transformer that might be shorting to ground. If no transformer, the control panel or the control board has a short.
Mar 11, 2011 | Baumatic F60 Stainless Steel Kitchen Hood
What causes headlights to keep blowing bulbs?I just replaced them and got about one hour of run time out of them.
When replacing a modern headlamp be sure not to touch the glass part of the bulb with your bare hands. The oil from your hands will ruin the bulb for some reason. Check to see if your lens assembly is letting water in this will blow the bulb instantly also.
Dec 02, 2010 | 2002 Kia Sedona
I have a 2002 Kia Spectra ls, why does the headlight bulbs keep blowing? My husband checked the ground, said it was ok. He replaced only the low beam bulbs, to see if the problem was with the high beams,...
Check the socket to see if voltage is spiking over 13.5 volts with a voltmeter while revving engine . Charging could be bad.Look for bare wires around the assembly as well.
Sep 25, 2017 | 2002 Kia Spectra
Why am I blowing my Bulbs?
Replace the bulb power driver.
May 23, 2010 | Sony KDS-60A2000 60" HDTV
1995 polaris 425 magnum 4x4 blows the tail and headlight bulbs. replaced regulator..still does it. battery shot. does it have to have a good battery hooked up in order to work properly?
i had a polaris scrambler three wheeler and it would blows bulbs also, it had a junk battery in it, never thought anything of it, read up on it and if the battery has a short in it, it will blows the bulbs, replaced the battery and didnt have any more problems blowing bulbs
Oct 04, 2009 | Polaris ATV
Headlamps keep blowing
may be you should go for genuine lamps from the compan y and that too of same voltage.. check if you are puttig bulbs of lower voltage and bulbs getting blown up.. if it is not so then get your induction coil checked..may be its producing more current than required and blowing up the lamps.. i hope this will help you out.. belated Merry X-mas and Happy New Year :)
Dec 29, 2008 | 1997 Nissan Sentra
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
275 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
