Question about Car Audio & Video
Which wires connect to what.
I have an a long mill graphic equalizer to go in my car.
The problem im having is there are 4 phono cables coming out of it.
i dont know which connects to were?
I have some idea that one comes from the head unit the other 3 go to the amps. But which ones.
  • 578 Answers
Not that not how is goes the one from the radio connect to radio and from the eq to your amp hope this help you
Posted on Jul 07, 2009
  • rteemon
    rteemon Jul 07, 2009
    not that not how is goes the one from the radio connect to radio and from the eq to your amp hope this help you
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
According to manual there is pre/amp on Pioneer sx 20 what connections do I use to connect graphic equaliser
Yes, the SX20 includes a preamp including a phono stage. (nice!) There is already equalization in the SX20 available via the bass/treble controls. To hoop up an external graphic equalizer, you should be able to connect it to the 'Recorder' IN/OUT and then select the tape monitor input to hear the equalized signal.
http://www.hifimarket.cz/files/img/zbozi/pioneer/_640x480/sx-20-4.jpg
Jan 26, 2015 | Pioneer Audio Players & Recorders
Studiomaster manual
On the rear panel there are two jack socket marked: Left and Right Insert.
These are connected to the graphic equalizer using two insert cables, one for each channel ( L & R). The cables have a stereo 6.35mm jack plug which plugs into the mixer, the cable splits into two mono jack plugs marked tip (or send) and ring (or return). The send (tip) connects to the input of the graphic equalizer and the return (ring) connects to the output of the graphic equalizer. How it works: The stereo jack interrupts the signal in the mixer and sends it to the equalizer, the equalizer processes the signal then sends it back to the mixer. Typical cable is shown below. If the equalizer has a different type of socket, phono for example you will need jack to phono adapters or insert cables with suitable plugs. Hope this helps.
Apr 05, 2014 | Audio Players & Recorders
Don't no how to hook it up ...
Instructions
Hook up an RCA patch cable
between the output of your car's
stereo receiver and the graphic
equalizer's RCA inputs. Use
stereo cables with male RCA
connectors.
Connect the equalizer's outputs
to the RCA inputs of your
amplifiers. How many cables you
need will depend upon the
number of amps in the system. In
most cases, you'll need two to
three to connect the equalizer to
the inputs of your amplifiers.
Hook up the equalizer to 12-volt
power. Use the same power
connections you used to connect
your amplifiers and receiver. The
equalizer's yellow wire should be
connected to a constant power
source, one that is not switched
off with the ignition, and the red
wire (not always present) to a
switched 12-volt power source.
Splice the wires by stripping the
insulation off the end of each
wire and then soldering or
crimping them together.
Connect the equalizer's blue
"turn-on" lead to the receiver's
blue wire. This turns the
equalizer on when the receiver is
powered up.
Mar 28, 2013 | Car Audio & Video
Marantz nr1402 how to connect turntable
Connect turntable out to phono preamp In
Conect Phono preamp out to your Marantz NR1402 vacant analog input.
On your TV , if audio out is available connect it also on the Marantz
vacant analog input 2
Aug 01, 2012 | Marantz Nr1402 Av Receiver
I have just fitted a Technics SL BD20 Turntable to my new Panasonic SA-AKX50 system. I can't get much volume out of it when playing a record on the turntable. I have a black wire coming out of the back...
Does your NEW Panasonic SA-AKX50 have an input label "PHONO"? If not, it can't PRE-amplify and RIAA-equalize the tiny voltage signal produced by the phono cartridge.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
May 07, 2011 | Audio Players & Recorders
I need a wiring diagram for installing 2 LT980-2
do you need help just for the power or for the audio or both?
power it is simple
positive goes to the battery but with a fuse in the middle
negative goes to a metal ground point on the car (but not battery)
remote goes to the radio with should have a blue and white cable if radio does not have remote line then use the acc wire from radio
for sound
your amp does two speakers and im guessing you want the back ones amplified
so cut the 4 wires that come from the radio and goes to the back speakers 2 positive and two negative
and connect this to the input the phono terminals on the back (unless your radio has phono terminals for audio out on the back side
then take the output from the amp and run it to the speakers one positive and negative to each speaker
i cant seem to find a wiring diagram for that amplifier but i can give you a more genral diagram
http://www.caraudiohelp.com/how_to_install_a_car_amp/how_to_install_a_car_amp.htm
Jan 05, 2010 | Power Acoustik LT-980/2 Car Audio...
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
We took our separates system apart to move it and know we cant remember what wire goes where at the back!!! we have turntable, equalizer, amp, cd player
start with the most basic ie; your amp is the recipient for all your cables so start with the cd cables into the cd phono inputs, then the turntable to the phono inputs. finally, your graphic into either the auxillary phonos or alternatively into the tape 2 phonos. good luck.
Sep 06, 2009 | Technics Audio Players & Recorders
How to connect phono leads
  1. Step 1 Check the back of your Stereo for recording input(in) and output (out), your cassette deck may be plugged into these jacks.
  2. Step 2 Connect the RCA/Phono wires to your equalizer's input and output jacks on the back.
  3. Step 3 If your cassette deck or some other component is plugged into the recording jacks in the back of your amplifier, unplug it and plug it into the back of the equalizer under monitor jacks. Be sure that the "out" from the cassette deck goes to the "in" of the equalizer.
  4. Step 4 Now, take the wires from the equalizer and plug them into the amplifier in the same manner: "in" to "out" and visa versa.
  5. Step 5 Once all your wires are connected be sure the "tape monitor button" on the amplifier is on. Turning it off will disable the equalizer. You can still monitor your recording devise or cassette deck by the "monitor switch" on the equalizer.
Mar 12, 2009 | Audio Players & Recorders
Car Audio & Video Logo
192 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
