Question about Sony Playstation 3 (PS3) Console
Optical sound problem
Hi, I have my PS3 connected via HDMI to my screen and via optical to my Sansui RZ4900AV. The problem is I get a high pitched noise to my centre speaker when the PS3 is on. It is not very loud but it is irritating. Any help will be appreciated. Thanks
I have the same problem with the RZ-4900AV, it manifests itself when any video application runs through either the optical or coaxial input. in my case it's definitely not the optical cable itself, which works fine on another receiver. optical or coaxial input of audio CD's is fine, but a DVD video on the same DVD player gives the high pitched whine. the same with the PS2 on the optical input, audio CD in the PS2 no problem, PS2 game or DVD video gives the whine... i think, unfortunately, it's a crap receiver... and i solved the problem by buying a RZ-6900AV, which works perfectly in exactly the same environment.
Posted on Sep 28, 2007
SOURCE:
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
I own a Yamaha RX-v365 and i cant figure out how to connect my PS3 to the surround sound. For some reason the HDMI cables wont work. Any help would be greatly appreciated. Thanks
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
Oct 31, 2009 | Yamaha RX-V363 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Nov 16, 2008 | Sony STR-DB930 Receiver
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
Jul 28, 2017 | Sony KDS-60A2000 60" HDTV
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
PS3 HDMI PROBLEM WITH SOUND
I am pretty sure you need to have an Optical cable running from Your PS3 to your sound system...if you have one...
So basically you will have a HDMI cable running from your PS3 into your TV, another HDMI cable running from your TV into your sound system, then an optical cable running from the PS3 to the Sound system. I sadly own a HDDVD sound system but the optical cable tells it to accept the Blu Ray content.....
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
181 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
