Question about Dishwashers
Servis dishwasher constantly pumping
I have a 2-3year old servis dishwasher. I had to chance the outlet hose and forgot (duh) to take the plastic out of the tube and so it wsnt draining. After i did that the dishwasher pumped out all the excess water but now it won't stop pumping even though it's empty, even if i turn if off and back on at the mains it still pumps then flashes all the error buttons! Help!
Did you ever find a solution for this problem if so can you post what it was thanks
Posted on May 18, 2010
Dishwasher do not empty
Make sure drain hose is not crimped and is t a 90 degree angle
Sep 02, 2012 | Servis Dishwashers
Not filling up with water ,but is making a washing sound
Is your drain hose raised 19" FROM THE FLOOR. oN MOST MODELS YOU HAVE TO DO THIS FOR IT TO HOLD WATER IN THE TUB WHILE OPERATING AND THEN it pumps it out
Mar 12, 2012 | Dishwashers
Dishwasher not draining have tried a dishwasher cleaner and plunged the sink but problem remains the model is a Servis M491
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a dish-washing machine, due to food waste clogging the drain. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Aug 08, 2011 | Servis Dishwashers
Washing machine problem
press the half-load button when you need dryer to work, make sure wash dial is at end position
Feb 03, 2010 | Servis Dishwashers
I need a manual for Servis M6012W washing machine
I did not have a dishwasher, as my question says I wanted a Manual for a washing Machine.
Jan 15, 2010 | Servis Dishwashers
Not draining
need brand and model #. usually either a problem in the pump or an obstruction/clogg in the drain hose or disposer.
Jan 05, 2010 | Servis Dishwashers
Servis washing machine fills but wont turn
is it a brush motor? if so the brushes may be worn, secondly the motor control pcb may have blown. also check the wiring.
Mar 18, 2009 | Washing Machines
Dishwashers Logo
299 people viewed this question
Top Dishwashers Experts
Owen Barnes
