Question about Lenovo ThinkPad T43 Notebook PC
T43 fn+f5 utility IBM ThinkPad Fn+F5 Utility has encountered a problem and needs to close. We are sorry for the inconvenience.
I pressed fn + f5 but the bluetooth did not turn on
Make sure that the drivers are installed properly if so then you can update the drivers via below mentioned link,
Bluetooth:http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61425click on 7jba10ww.exe and download the driver.
Optionally you might require to update the hotkey utility, sometimes it happens that hotkey software gets corrupt and does not shows any problem other than activating/deactivating
Hotkey:http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-74261#systemClick on 83vu18ww.exe and download the driver
Install the drivers and restart your laptop it should work then
Regards,Bilal
Jan 11, 2011 | IBM ThinkPad T43 Notebook
Tip
How to turn on Wireless Switch on your Laptop or Notebook PC
How to turn on the wireless switch on the laptop or notebook
If you have issues in finding the wireless switch on the laptop to turn the wireless on you can refer the below list
1. Dell D600 & D610-Key Board-Fn+F2
2. HP NC4000 & NC4010-Button-Above Keyboard
3. HP NC4220-Button Left Side of Laptop Near USB Port
4. HP NC6000 & NC6220-Button above Keyboard
5. HP NX9010-Button in front side of laptop
6. HP Omni book 6200 Button on Left side of laptop
7. IBM T43 & X32 Keyboard combination Fn + F5 then Click "Turn On"
8. Toshiba M1 & M2 Switch Left side of laptop towards
front
9. Toshiba R100 Switch on the Right side of laptop
10. Toshiba TE2000 Switch on the left side of laptop by Volume ctrl
11. Toshiba Tecra 2100 Switch Left side of laptop by Volume ctrl
12. Sony Vaio - switch on front left
13. Dell - FN,F2 or FN,F8 or FN,F12
14. Acer - FN,F5
15. IBM / LENOVO
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the FN+F5 key-combo.
IBM ThinkPad (General) - Most have software switch or button on Left hand side.
Lenovo T-61 - Slide button on the front of the laptop
16. MEDION
General - Fn+F1 or Fn+F2
17. MSI
General - Antenna-like button close to the power switch
U100 - Fn+F11
18. PACKARD BELL
Easy note B3600 use the Fn+F1
Easy Note E2/MV46/008 - Fn+F1
Easy note W7730, Antenna-like wireless button on the side of the laptop.
MZ36-U024 - Fn+F2
19. PHILIPS
General - Fn+F2 key combo
X54 - Antenna-like button close to the power switch.
20. SAMSUNG
General - Blue button found in the middle section of the keyboard
on Dec 03, 2009 | Computers & Internet
I can't turn on my wifi connection
try hitting FN+F5, so the function key and the f5 key at the same time function is listed as fn on the keyboard you will then get the option to turn on
Jan 05, 2011 | IBM ThinkPad T43 Notebook
Wireless issues
pressing FN+F5 for output to external video suppport, look there is a small button with lock for wireless.
Feb 26, 2010 | IBM ThinkPad T30 2366 Notebook
Radio switch off
To switch ON the radio function use combination of Fn + F5 keys.
Regards;
Hasan
Dec 26, 2009 | IBM ThinkPad T43 Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
Where is the wireless switch for ibm t42 laptop i have tried fn and f5 nothing works
There will either be a switch on the side of the machine or it will be fn and one of the funtion keys, look for an image like this:
http://hpshopping.speedera.net/www.shopping.hp.com/shopping/images/overview/wireless_black.jpg
Nov 26, 2009 | IBM ThinkPad T42 Notebook
T43 Lower Touchpad Not Function
Thinkpad Fn+X drivers are needed, or someone removed the resident routines.
For example my T41 has 5 thinkpad drivers for full thinkpad functionality, e.g. wireless connection, A/C monitor in the tray, as well as the Fn+X keys, mute, etc:
This is from my registry
"BMMMONWND"="rundll32.exe C:\\PROGRA~1\\ThinkPad\\UTILIT~1\\BatInfEx.dll,BMMAutonomicMonitor"
"BMMLREF"="C:\\Program Files\\ThinkPad\\Utilities\\BMMLREF.EXE"
"ACWLIcon"="C:\\Program Files\\ThinkPad\\ConnectUtilities\\ACWLIcon.exe"
"ACTray"="C:\\Program Files\\ThinkPad\\ConnectUtilities\\ACTray.exe"
"NPDTRAY"="C:\\PROGRA~1\\ThinkPad\\UTILIT~1\\NPDTray.exe"
I don't know what your background is, but this just indicates what is INSTALLED, not how to fix it - you need to "get" the drivers and THEN your registry (an advanced topic) will have these and they will work.
Jul 15, 2009 | IBM ThinkPad T41 Notebook
Wireless radio control problem
Try going into the Device Manager and making sure the Wireless Adapter is enabled. Click Start > Control Panel > System. Click the Hardware tab then click the Device Manager button. Now click the Plus [+] next to Network adapters then double-click the wireless adapter which is probably the Intel(R) PRO/Wireless 2915ABG Network Connection which will open the Properties dialog. Ensure the Device status reads, "This device is working properly" and Device usage shows "Use this device (enable)." If either the Device status or Device usage shows anything other than what is shown above, first try to change the Device usage, which should change the Device status. Now try again to use your wireless adapter. You might need to press Fn + F5 to turn the device on.
Nov 03, 2008 | IBM ThinkPad T43 Notebook
Lenovo ThinkPad T43 Notebook PC Logo
303 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
