Question about Yamaha 12V Air Pump
I have a 1986 Yamaha 50hp outboard 50DETO with a 703 remote. The problem is the trim and tilt only goes up and intermittently goes down I have had the switch in pieces contacts are fine can anybody help
  • Jeff Field Apr 28, 2009
    Thanks landsend all it turned out to be was a bad conection next to the solenoid, apparently yamaha's are nitorious for bad earths also
    Genius:
  • 1,066 Answers
You have bad solenoids.  Replace them and things will be fine.
Posted on Apr 12, 2009
Will low fluid level cause power trim/ tilt go not hold position
Low fluid level will cause it to fail to actuate and not go up or down, can also let it not hold position as well. Filling to proper leevel with specified lubricant is recommended. If you allow the level to go too low, the pump will pull air and could burn out.
Sep 21, 2014 | Yamaha Tilt Trim Motor, 40-90 HP Outboards...
Wat is the spark plug gap fo 50hp mercury two stoke 2009
The plug gap is most likely .040, however can you please confirm your serial number?
Sep 10, 2014 | Mercury Force Tilt Trim Motor, 25-50 HP...
How do I replace the motor on a yamaha power tilt and trim 1995
loosen engine mounting bolts and steering tube , trim engine up by releasing the valve on the side and tie up so not tocome down ! remove pin on the ram then remove all bolts and wires and should come out !
Jul 20, 2014 | Arco Yamaha Outboard Power Tilt and Trim...
We have a 1998 yamaha v4 2 strock 115 engine. we can not get the motor to go down. even if we try to drop it manually
lock lever not down ? does it move up and down at all , the tilt tube could be siezed ,both trim solinoides working ? try standing on the engine gearbox as you trim down or manually release ! if then goes down try injecting the grease nipples with petrol via a grease gun that uses tubes like tooth paste and this will soak the corrosion ! then grease and see if free and if not enough then lift the engine off and remove the tilt tube and clean the sleeves and grease and refit !
Apr 09, 2014 | Light Outboard Motor Boat Bass Fishing...
How to service a tilt/trim on a 50 hp yamaha outboard. I think the fluid is low as the trim will leak back down after raising the engine.
To check the fluid level, tilt the motor up and engage the tilt lock lever. Open the bolt on top of the tilt/trim reservoir. The fluid should be even with the bottom of the bolt hole. If not add some fluid. When you put the bolt back in, run the trim up and down a few times. That should purge any air out of the system. Always be on the lookout for any leaking hoses or fittings. Hope this helped and best wishes.
Aug 31, 2009 | Boating
I have a 1994 150 hp Yamaha outboard motor with tilt-trim. My motor is stuck in the up tilt position and will not tilt down. It is working when I go up, but not down. I have talked to a used parts dealer...
Stop! Dont replace the pump...I would bet that it is the "down" Solenoid that went haywire. I would begin by replacing the Down solenoid...it is a far easier and cheaper fix and if your pump works to raise the engine then that tells me that it is not faulty. The Down solenoid looks just like a starter solenoid and the one that you are looking to replace has a GREEN wire to it. Yellow with a red stripe is for the starter. Blue wire is the up solenoid. So replace the one with the green wire going to it and I bet it will fix your problem.
Jul 14, 2009 | Boating
Yamaha 12V Air Pump Logo
815 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
