Question about Evenflo Baby Gear
Folding play pen has one side jammed
My evenflo easygo play pen has one side(one of the long sides) stuck in the folded posistion and won't lock I tried to refold many times but it won't unlock
3 Suggested Answers
SOURCE: Folding up Cosco play yard
To fold the Play Yard:
1) Take out floorboard. Pull up on finger tab in center of floor
and raise midway to top rail.
2) To unlock top rails, push in on indicator buttons on each side
of rail. (Pull up slightly then push down.) Do this for each of
the top rails in any order.
(Note: If locks fail to release, pull center finger tab and lift
center lock higher.)
3) Continue to pull up on finger tab to raise the floor and pull in
the legs.
4) Wrap floorboard around play yard and fasten strips. Place
inside carry bag for easy transportation.
Posted on Feb 25, 2008
  • 11 Answers
SOURCE: One of the sides(the wider one) is locked in the open position.
On our pen the linkage was famous for binding at the junction(elbow) some slide forward to release, others must be squeezed, the best way to start is to flip it up on its side or rite upside down, just to reroute the pressure and (hopefully) allow the binding junction to release and fold. you'll have to fiddle with it but it should go. if its newer call the manufacturer, faulty bady goods can be cause for very costly legal infractions(they could get sued!)
which means they should try to help you out and hey, you find out your not the only person with this problem on this playpen.
hope it works out for you , Jon
here are a link with a couple of recalls:
http://www.fcsafekids.org/PDFs/Hotel%20program.pdf
Posted on May 21, 2009
I need to fold the evenflo exersaucer to store it
Unfortunately, folding it to store is not a simple task. You'll have to remove the base which will allow you to fold the legs. Although the article I'm referring you to is for converting the exersaucer into a stage 3 activity table, it does give instructions on how to remove the base which will allow the legs to fold. How to Convert the Evenflo Exersaucer into Stage 3
Feb 05, 2014 | Evenflo Exersaucer Triple Fun Active...
I can not get the sides to lock-in. What is your suggestion? My play pen is Century Fold-n-go TM Deluxe Care Center.
I think I may know how to solve your problem. I had a similar issue with the pack and play my mother-in-law gave me.
It seems to never work if you set the play pin up right and try to lock the sides up. Tug and pull all you like it just wont do it. I would suggest that you collapse it completely, then try to lock the sides, short first, while the system is either upside down or on its side. Then lock the longer sides.
This is what worked for me at least. I hope this helps. :)
Sep 27, 2010 | Toys
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
Folding:
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
Bought an older evenflo comfortflow stroller. Can't figure out how to break it down. Printed on handle: pull up, squeeze, push down. Nothing happens.
I own one also. I think the button gives out over time but don't worry it still folds. Look at the front of the stroller like your putting a kid in you will notice two handles one on each side, there are buttons on both and they jam sometimes, push the buttons in an pick up at the same time and it will fold.
Sep 13, 2009 | Evenflo Baby Gear
May 21, 2009 | Baby Gear
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
Cosco Playpen
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
By the way, I've found it to be an exercise in frustration in trying to obtain an instruction manual from the manufacturer. I'm very disapopinted with this purchase and in particular this company.
Hope this helps!
Jul 01, 2008 | Cosco Beatrix Potter Playard Crib
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Buggy wont fold down
Problem suggests that you have not followed the user operation procedure correctly and hence damaged the folding mechanism.It is possilble you may have damaged locking gear of the folding mechanism on the left side while trying to fold the equipment sometime during earlier operation.You may like to consult a service engineer to fix the problem
Aug 10, 2007 | Bugaboo Cameleon Jogger
Baby Gear Logo
311 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
