Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
Can not find where to put the PWR S/W on MB
Got a used FOXCONN MB. It has the number N15235 near the GPA slot and 661MXPLus by the DIMM slot. I am unable to find where to put the PWR S/W & LED from the case. Am not able to find a manual online but found this site. Can you help??
Look on the mother board for a group of pins, two rows, the top row will have one less pin then the bottom row. right next to the missing pin is the two pins needed for your power switch. touch a screw driver to one of those two pins one at a time and that will tell you which one is pos.
Posted on Apr 13, 2009
Characteristics of n15235 manual motherboard
- IntelĀ® Pentium D, PentiumĀ® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
Also, if you need drivers for all that components, use this tool: http://tinyurl.com/n8nrz6t.
regards
Sep 16, 2011 | Foxconn 6627MA-RS2H Motherboard
Need specs for the N15235 motherboard.\r\nIt has a
The link provided by Foxconn shows all supported CPUs that will work on the Foxconn 6627MA-RS2H MB; http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&model=6627MA-RS2H&cputype=
Cheers'
Mike
Jun 06, 2010 | Foxconn 6627MA-RS2H Motherboard
Foxconn motherboard n15235 no viedio
That motherboard is either a P4M800P7MB-RS2 or a P4M800P7MB-RS2H, even thou it has N15235 stamped on the board. The board
Supports VGA display function (S3 Graphics UniChromeTM Pro IGP)
but, also has an AGP 8X slot. A slot that allows you to install a AGP 8X (AGP 3.0) card. A AGP 8x is the VGA interface specification that enabled enhanced graphics performance with bandwidth speeds up to 2.1 GB/s.
Hope that answers your question.
Mark
Apr 23, 2010 | Foxconn 6627MA-RS2H Motherboard
What are the memory specifications for the Foxconn 661MO3C-6L?
The memory specifications are as follows...
System Memory
Two 184-pin DIMM slots
Supports PC 3200/PC 2700/PC 2100 memory
Supports 128/256/512 Mb technology up to 2GB
Mar 17, 2010 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
Foxconn n15235 memory support?
The Foxconn n15235 isn't the correct designation.This is a propritary designation from EI SystemsFont Definitions */ @font-face {font-family:PMingLiU; panose-1:2 2 3 0 0 0 0 0 0 0; mso-font-alt:新細明體; mso-font-charset:136; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:3 137232384 22 0 1048577 0;} @font-face {font-family:"\@PMingLiU"; panose-1:2 2 3 0 0 0 0 0 0 0; mso-font-charset:136; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:3 137232384 22 0 1048577 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:PMingLiU; mso-bidi-language:AR-SA;} @page Section1 {size:595.3pt 841.9pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> the motherboard in your system is actually a Foxconn’s P4M800P7MB.
User Guide can be downloaded here.
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0000569
System Memory
· Two 240-pin DIMM slots
· Supports DDR2 533/400 memory
· Supports 128 Mb/256 Mb/512 Mb/1 Gb technology up to 2GB
Jan 27, 2009 | Foxconn 6627MA-RS2H Motherboard
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
Help Please
You're Foxconn N15235 must be in a PC case from another Mfg.
EX: Packard Bell IXtreme 2711. Please tell me what machine the board is in. If its the above system than it can take Two 240-pin DDR2 SDRAM DIMM slots. Single Channel DDR2 400/533.
Supports up to 2 GB system memory.
Jun 02, 2008 | Computers & Internet
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
Foxconn manual for a n15235
There is no Foxconn mainboard (and will never be...) called N15235 although this is printed on the board. The right name is P4M800P7MB-RS2H and you can find all stuff here: LINK
P.S.: you can find the right model number printed on the board beside the RAM slot near the CPU and on small label above.
Tom (mailanmeyer@gmail.com)
Feb 18, 2008 | Computers & Internet
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
245 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
