Question about Zanussi 24 in. DE6850 Free-standing Dishwasher
ZANUSSI DE6855 DISHWASHER - NO HEAT FOR WASHING OR DRYING
It appears to progress through the cycles ok so I am thinking a heater problem? If so how is access gained to the heater? Any previous experiance on this fault would be appreciated.
Make sure you unplug before you start. I had the same problem with a DE6850. The heater was ok. Metered at 25.ohms. Apparently, the relay on the control board mounted in the front door behind the switches is a common fault. Remove the screws around the top part of the door and you will be able to get at the control module. Resolder the connection. Zanussi reliability has been lost. Noel PZANUSSI DE6855 DISHWASHER - NO HEAT FOR WASHING OR - 31bf5e2.jpg
Posted on May 08, 2009
  • smdb59 Jan 27, 2011
    Brilliant
    Perfect advice - DW now working again. I thought at first it would be the element but after circuit testing it as OK I found this web page.
    Thanx
  • Lee Laws Mar 01, 2012
    My DW started having the same problem. I was ready to buy a new one until I read this and now I've fixed it. Brilliant advice! Thanks a lot!
+1 for the above. Followed the steps for the exact same fault. Sure enough, once i got the circuit board out, the burnt out solder joint looked the sam as the above picture. Re-Soldered the joint and all seems to be working well...Many thanks..
Posted on Jun 06, 2010
I have a Zanussi Izzi Alu dishwasher and it won't heat the water. But after following the steps mentioned above (especially resoldering the connections on the control module) it works perfectly again. Thank you very much for this solution!
Posted on Feb 25, 2010
Dishwasher Halting
1) test for some wires connector loose inside of control board
2) test for fuse or c.breaker contacts loose, or corrosion, clean unplugged the machine.+test the power cord for open
3) runt the diagnostic test, read you instruction manual for help.
4)see if the water supply is open this cause not start the washer
5)motor overheating, the motor had been designed for to run until complete the cycle, wait by 40 minutes for to cool the motor. and try the cycle again.
6) Lid switch mus be close very well , test the switch for open or defective.
Jul 18, 2012 | Washing Machines
I have Zanussi DX6453 dishwasher. Suddenly it is not drying our dishes. All programs working. Do you think is problem with Element or Thermostat. It is heating water.
sugget the water temperature, it relies on the temperature of the water to heat to items up so that when the wash cycle has finished the heat will dry them. Hope this is useful. Regards Mike
Jul 07, 2011 | Zanussi Dishwashers
Electrolux de 6850 dishwasher
I followed some of the good instructions already on Fixya. I had checked the heater and it was o.k. I then took the front door of the washer apart to get at the control box. Sure enough, I also had the common design fault. One leg of the rely had scorch marks and was now disconnected from the circuit board. I will solder tonight and test. I include a photo of the burned board. TNoel P8017c86.jpg
May 07, 2009 | Zanussi 24 in. DE6850 Free-standing...
Zanussi da4342 dishwasher
The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective. If you have observed anything different post a comment.
Jan 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
Zanussi de6855
most probably the pcb unit...had a few of these changed pcb and cured fault, not a job for a novice to be honest, think the parts is about £70-80 from memory.. ally
Jun 30, 2007 | Zanussi 24 in. DE6850 Free-standing...
Dishwasher was tipped and won't run
I have the same problem if you take off the tray below the front door and set a small blow heater in there it will dry the out the anti flood switch. It usally takes about 25 mins for the machine to start working again.
Feb 21, 2007 | Zanussi 24 in. DE6850 Free-standing...
No heat
You should check for 115/220v on heater tags, In case you don't have it, your problem is a malfunction thermostat that should be replaced. Good luck!
Dec 06, 2006 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi 24 in. DE6850 Free-standing Dishwasher Logo
2,367 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
