Question about FrancisFrancis! X1 Espresso Machine
Machine not heating. Power problems
When I plug the machine in, only the top power light goes on. When the power switch is on the boiler light does not go on. The only switch that seems to work is the brew switch. Nothing happens when I turn on the steam switch either.
  • etta007 Jan 22, 2008
    just got the machine, it worked for two days and then the heater conked out and the pilot light is no longer going on. How do you "check inside??"
  • Anonymous Mar 19, 2009
    I turn the machine on and it just doesn't heat - any ideas?
  • 625 Answers
Check inside for burnt spade connectors or wires burnt off the connectors. spade connectors can be gotten from radio shack or electrical supply houses or home depot.
Posted on Sep 11, 2007
SOURCE:
I bought my senseo philips HD7825. I loaded the water then plugged it in then I added the coffee pod. However, the power light kept blinking (slowly) as though it is heating up. But it is not heating.
Hi
Quite possible the boiler has failed. You would need to disassemble to check (with a multimeter) if the boiler heater elements are a continuous track from one terminal to the other. Boilers often fail - else you have a electronics problem somewhere that will require a tech person check out.
The other thing boilers can do is to develop an earth leak between the heater element itself and the outside of the element - this will cause the machine to shut down your house's power supply if you have an Earth Leakage Safety Switch installed in your meter box.
Given this was an inexpensive machine and uses rather "odd bod" pods it may be time to consider something more 'common' like a Nespresso, Aldi or the Cafitaly style of capsules.
I especially like the Cafitaly capsules as they have more coffee than Nespresso, have 2 internal filters, can be refilled with ground coffee (I reseal top with wide cellotape) and can be refilled at least 4-6 times before they should be thrown away. Instead of around 30-50c a cup, refilled capsules costs me about 9c a cup - I get about 100 capsules out of 1Kg (2.2 pounds) of coffee.... beat that.
Cheers
Mike
Dec 10, 2017 | Philips Coffee Makers & Espresso Machines
Kitchenaid espresso machine tripping switches
Relay will be fine if you fix the real problem. Get some new seals (5 of them) into the steam boiler and check for leaks from the teflon tube at the top of the steam boiler. When you have it apart tip it upside down, you will be surprised how much hidden water there is.
May 21, 2012 | KitchenAid Artisan
Lights are all on but the machine not heating so power up lights will not turn odd
Hi There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won't heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged. If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Jul 10, 2011 | Rancilio Silvia Espresso Machine
Our la cimbali m29c12-mf heats up for a few minutes then cools down then heats up again. What is the problem?
1Check the inlet cable of electricity 2 Check the heating element and heating element controllers (thermostats).
Feb 09, 2011 | Espresso RMI La Cimbali Espresso Machine
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
Older Faema double head. Power light on, but
It is on the right side of the machine behind the grouphead if you remove the top panel you will see te box with the red switch sticking out. MAKE SURE THERE IS WATER IN THE MACHINE FIRST!!!!!! Do not trust the sight glass, if the level probe is in there, turn machine to 1 then disconnect the electrical connector on the side of the sight glass, the pump should kick in and water will flow in the boiler, if the level does not increase in the glass, then the machine turned itself off because the element got too hot from lack of water. The hole for the sight glass is blocked.
Jul 31, 2009 | Coffee Makers & Espresso Machines
Livia 90 - Power on no pressure
When you say no pressure do you mean steam pressure or water pressure?
If it is steam pressure the machine is not heating up, then the elements could be damaged, disconnect the machine from power open top 4 screws on the top panel, you will see the boiler and element(middle of the boiler with 1 wire on each of the terminals) disconnect both of the terminals and check for resistance between the terminals, if you get a reading then the element is fine.
The bottom level sensor is not reading the water level and told the machine to not heat(stainless steel probe sits on top of the boiler there are 2 of them one checks the min water level and other checks the max water level, disconnect one of them and using ohms meter check reading from the stainless steel level to the top of the boiler, if there is a reading connect and then check the other one using the same method. If there is no reading on any one of those they might be covered with scale buildup or there is no water in boiler.
The machine cannot read the water reservoir(screw with ground connection on water tank).
There is also the Pressure stat(black box which sits on top front right of the machine with 2 electrical wires going to it), remove wires and check with ohms meter.
Mar 27, 2009 | Pasquini Livia 90 Espresso Machine
Switch or Fuse?
Probably the thermal reset on top of the boiler.
Mar 26, 2009 | Gaggia Achille lever operated espresso...
SL 90 Machine not heating
Hi There are 3 things that could be the problem. 1. The power board on the left rear inside. 2. Heating element is burnt out. Replace the top part of the boiler and order a brew head gasket and replace it at the same time while you have the machine apart. 3. and less likely is the temperature sensor. 2 red wires goes from the board to the top of the boiler.
Nov 16, 2008 | Solis Crema SL-90 Espresso Machine
Francis Francis x5
Almost certainly, your heating-element is corroded through, and with the...questionable...design of this machine, power continues to flow unchecked through the "substitute neutral" of your machine's case and ground wire, so it keeps working, sorta, until things burn out so badly within the boiler that you can't make a connection. Low boiler water-level might break that connection, too - that's how sketchy this design is. There's a reason the national electric code (and common sense) call for switching the HOT side of a circuit: to minimize the potential exposure to power as long as the switch is off. While the power-switch on this unit may do this, the F-F's thermostat, however, switches the NEUTRAL side, leaving it unable to do anything to prevent stray power from heading merrily through the machine via the ground, once your heating element has corroded through - which is a guaranteed failure item, just a matter of time. Sucks, don't it?
You could replace your element with an after-market version if you're game, but it's not a simple or quick fix. See http://www.fixya.com/support/t1029310-x5_boiler_share_did_replacement .
Jul 08, 2008 | FrancisFrancis! X5 Espresso Machine
FrancisFrancis! X1 Espresso Machine Logo
212 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
andyandrews3
Level 1 Expert
ray gallant
ray gallant
Tom Chichester
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
