Question about NEC MultiSync GT1150 Multimedia Projector
Sanyo Projector==No signal
Sanyo projector is not registering a signal when connected to a Dell laptop. I followed set-up procedure--first, connect machine. Then turn on projector, then laptop and hit "FN + the LCD button (F8)"
  • 2 more comments
  • Anonymous Nov 20, 2007
    My problem is that the Dell Inspiron 1300 laptop will drive a Sanyo projector but an Acer PD125 projector shows "no signal". I have tried reducing thescreen resolution.
  • lc_golden Oct 05, 2008
    Lightware scout will not detect a source even though it is connected to my Toshiba
  • Anonymous May 10, 2009
    How do i connect my sanyo projector to my samsung nc10 laptop?
  • Anonymous Mar 31, 2014
    Thick black line on centre of screen. Sanyo short throw projector
  • 43 Answers
This happens a lot with the Dell laptops. The reason is because of the frequency that is being sent out on the laptop. Try toggling the laptop to where your laptop screen is black. (if laptop screen doesn't go black, you may have a bad cable). Next try lowering the "refresh rate" to around 60 Hz with your resolution at or below 1024x768.
Reason for the toggle to black is because if both screens are visible (Dell only I believe) the frequency out is lower than that of the computer and the projector has problems syncing up.
Posted on Jan 06, 2009
    Brigadier General:
  • 6,966 Answers
Hi, Perhaps you can try lowering the screen resolution first of the laptop before plugging in the projector and then the Fn + F8. Thereafter, gradually increase the screen resolution until projector stops displaying. The idea is that your current screen resolution maybe too much for the projector to handle. This of course is assuming that there is no hardware problem with the projector. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 14, 2007
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ... > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
I follow the set up proceedure to connect the projector to my acer laptop. I then switch on power to the projector and boot the laptop. After the 30 second count-down I et a no signal message which stays...
Not wishing to show Grandmother how to **** eggs, but there are three VGA sockets. One of them is VGA out.
Can you select the inputs on the menu system?
Hope that helps.
Feb 23, 2011 | Sanyo PLC XU30 Multimedia Projector
We are using a Dell 2300 projector. The Power
check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
Apr 12, 2010 | Dell 2300MP Multimedia Projector
DLP Projector connection to Laptop
you need to go to te control pannel and go to display settings then manually select the external monitor then hit apply it will open on your projector
Nov 02, 2009 | Office Equipment & Supplies
I have connected the projector to my dell laptop and there is a message "searching for signal" coming up. What do i have to do?
Once the projector is connected to your laptop, and both devices are powered on, press the Fn + F8 keys on your laptop to toggle your screen to the projector.
Oct 11, 2009 | Dell 2200MP Multimedia Projector
Macbook compatibilty with Sanyo PLC-XU32 projector
Force the frequency on the mac to 60hz. The projector can't respond to the high clock rate of the mac. Contact sanyo for a firmware upgrade to this product as well
Jan 27, 2009 | Sanyo PLC XU32 Multimedia Projector
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Searching for signal
There is an "Auto search for signal" setting on the projector settings menu. This may be turned off.
Oct 04, 2007 | Dell 2200MP Multimedia Projector
NEC MultiSync GT1150 Multimedia Projector Logo
1,693 people viewed this question
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
