Question about Panasonic ET-LAE500 Projector Lamp for PT-L500U, PT-AE500
Yellow splodge on Panasonic Projector
If my 'Panasonic LCD high definition Projector PT-AE500E' has a yellow splodge while playing movies on it, what does it mean? And can it be fixed?-And if it can, how so? Please tell me what I need to know to fix this projector.
SOURCE: error in panasonic lcd projector/projecteur lcd model no PT-LM1E-C
ESTOI BUSCANDO MANDO PT-LM1E-C
Posted on Jun 08, 2008
SOURCE: PANASONIC LCD PROJECTOR MODEL # PT-AE900U
The manual says that it will do this as a reminder that it has ended the recommended lamp life (on mine PTAE900E this starts at 2700hrs and supposedly can blow from then until the max of 3000hrs)
sounds scary enough i guess but they put that 10minutes on/off thing in there to kinda force you to get it changed...
mine is at 2600 anyone know of a good place to get a new lamp in melbourne australia?
cheers dave
Posted on Jan 16, 2009
projdoc
  • 2237 Answers
SOURCE: Panasonic projector TV PT-43LC14 has a light
yes and no. it is a burn spot on the light filter on the blue lcd panel due to excessive dust and heat. panasonic does not sell individual parts of the optical engine, so you'll have to replace the entire engine. to avoid it happening again or getting worse, keep the projector cool and dust free. use canned air to blow it out.
Posted on Nov 30, 2009
  • 144 Answers
SOURCE: Panasonic PT-AX200E LCD Projector - green screen
lcd has gone ajust it
Posted on Jan 31, 2010
SOURCE: the projector lamp does not turn on
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
Posted on May 13, 2010
A yellow blob in the middle of the picture and it seems to be growing
1,check it ,clean the Lcd panel with alcohol, maybe the yellow blob will disappear
2,if it is not,it seems that the LCD panel is failing
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 29, 2014 | Panasonic PT-LB60NTU LCD Projector
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
Jan 04, 2012 | Panasonic PT-AE2000U Projector
Screen is yellow in the middle?
If the yellow area edges are sharp then the blue LCD is faulty and need to be replaced.
If the yellow area edges are not sharp and you get the multi color background in you image the your need service. due to dust on LCD panals the light is not pass on properly so you open the projector and clean the LCD block.
(cleaning of LCD block and other parts of the projector is a very technical job please very very carefully)
Jan 25, 2011 | Panasonic PT-AE1000U LCD Projector
I own a panasonic pt-ae900e i have notice a thin uneven green transpairant line in the middle of the screen lamp time 1987 hrs
Experience:
There is three LCD (liquid crystal display) in your projector when one LCD faulty he display a line some time flickering line one or two lines. Due to other two LCD is working well so this line is looking transparent. If BLUE LCD faulty than the line color is very light green or yellow.
Second option is this that your projector lamp life is near to end and after 2000 hours projector is very dirty inside and need service.
(service of LCDs and other parts of projector is a very technical job and I don't know you can do it or not)
Jan 16, 2011 | Panasonic PT-AE900U Multimedia Projector
Panasonic projector TV PT-43LC14 has a light yellow splotch on the left hand of the screen. Can this be fixed?
Nov 30, 2009 | Panasonic PT-AX200 LCD Projector
Yellow middle, Blue Exterior
Hi Druaga
This is a Blue LCD Polarizer that will have to be replaced if the spot shows yellow.
You will find that this will only get worse as time goes by.
May 28, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-50LC14 LCD rear projection
well it gets real compicated, if you are good with electronics and can take apart and put back together the inside the projector needs cleaned or the easy fix replace light engine about $600.00 rebuilt
Oct 07, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic ET-LAE500 Projector Lamp for PT-L500U, PT-AE500 Logo
128 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
