Question about Electrolux EW1000i Front Load Washer
The drum did not move (spin) eventhough there were the sound of moving (spinning).
  • matadam97 Apr 12, 2009
    where do i find the belt and how to open it?
    Sergeant:
    Champion:
  • 289 Answers
Hi..you need a new belt.Replacing the old one
will solve the issue.
try this out..
thank u..
rate me..
Posted on Apr 12, 2009
    Problem Solver:
  • 12 Answers
In order to replace the belt on this unit you will need to pull the washing machine out to access the back panel of the washer. Your belt may not have broken, although if any wearing on the belt reccommend you replace it and make sure it fits properly in the groves on the motor to keep on the back wheel(pulley) of the after you rotate the drum from the wheel and make sure it is on, (you may need a ziptie to be removed before use. Rotate atleast 5 times with power off to make sure it is grooved properly. Replace service panel and return power.
Hope this helps. D&J Tech
Note: if this unit is still in warranty call a service tech. this may void any current or extended warranty.
Posted on May 14, 2009
70 series model 110.82873120. Why doesn't it spin?
If it is trying to spin but not then most likely the clutch is worn out and slipping. Not hard to replace. Sits on top of transmission looks like a brake drum from a car.
Mar 04, 2016 | Kenmore Washing Machines
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
I am looking for wa10r3 samsung washing mahine washing but wont spin,sounds as if is spinning but wont spin.please help me
check underneath for a solenoid that engages a lever or clutch to connect the belt drive to the base of the tub
it it is not slapping in when it goes to spin , it will not spin
Dec 18, 2015 | Samsung Washing Machines
What would the cost be to tighten drum in washer
Sounds like the concrete weight is broken. It stabilises the unit while spinning.If the drum moves inside the tub, the bearing has collapsed
May 09, 2012 | Whirlpool duet Washing Machines
Scraping sound when you spin the drum by hand. The washer is two years old. front loader affinity model.
does the drum move as you spin it (if so poss stuts) makes a scrapping sound
Just check to see if the drum moves more than it should
Jul 28, 2011 | Frigidaire ATF6000ES Front Load Washer
Overload affected performance. Even when only got 1 item in machine. Makes lots noise when spinning and inner large plastic seal looks like something caught on it and shredded some of plastic.
this fault can be caused by the drum halves becoming tight .they move together due to limescale deposits between the drum spiders. the noise is most likely a failing drum bearing
if the plastic seal is damaged then it will need a new drum assembly
they are no longer available from dyson due to supply problems
you may be able to get another machine from ebay and fix yours using parts from each machine to make one good one
Nov 10, 2010 | Dyson CRO1 Front Load Washer
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washing machine wont spin
Try and help it to spin in the spin mode.. if it moves.. sounds like a clutch problem ..IF NOT... you may have something like nail, screw ect... binding the spin tub from moving.. get a flash lite do some close checking inside the spin tub
Aug 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Electrolux EW1000i Front Load Washer Logo
282 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
