Question about Harman Kardon HK 3380 Receiver
Amp comes on and goes right into protection mode Yes, same problem. Working fine. Thought it was due to heat or overload. Let it cool down, waited for 24 hrs. Worked for 30 mins the next day but then it happened again.
  • 10,594 Answers
Seems Protection activates in your amplifier due to over heat and cause can be air ventilation blocked or mismatched speakers.
Remove speaker wires from amplifier and check does it still go to protection after 30 min as mentioned above.
Please mention exact model of amplifier to see its schematics for further help.
How old is this amplifier, please intimate.
Hit "add a comment" button to reply.
Thanks.
Posted on Apr 12, 2009
My samsung htp 50 goes into protected mode after switching it on and then switches off again.......was playing fine the day before
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 07, 2011 | Samsung HT-P50 High Power HTiB with 5-Disc...
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
MY AMPLIFIER GOES INTO OVERLOAD MODE AN THE AMPLIFIER SHUTS DOWN . ALSO THERE IS NO VOLTAGE TO THE FAN AND THE FAN WON'T TURN.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Feb 28, 2011 | Panasonic Audio Players & Recorders
When you are watching a movie and turn on system it goes into protection mode and shuts off. Also when you are listening to music when the volume reaches a certain level(not very loud) it goes into...
Loose speaker wire somewhere or heat.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 26, 2011 | Harman Kardon Audio Players & Recorders
WHEN I TURN ON MY DVD PLAYER IT SAYS HELLO THEN IT SAYS LOADING THEN IT GOES RIGHT INTO THE PROTECT MODE I WANNA KNOW HOW TO TURN OFF THE PROTECT MODE FOR EVER I DONT WANT IT ON THERE
Resolve the reason it's self-protecting. Even if you COULD disable the protection feature, the Fire Department might not appreciate it.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 16, 2011 | Audio Players & Recorders
My denon avr 1508 goes into protection mode after 5 minutes of play. i have 8ohm speakers.
I'm thinking heat.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
Feb 13, 2011 | Denon AVR-1508 Receiver
Amp goes in protection mode
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on. Check for loose speaker connections.
Feb 03, 2011 | Yamaha RX-V461 AV Receiver
After about ten minuites of playing the amp shuts down and goes to protect mode.. I can then wait 2 minuites and turn it back on and it goes for a while again before repeating the sequence. Is it my...
Amps shut down due to, A: Short circuit, B: Overload. C: Over Heating. It is possible that the Output devices inside the Amp. get too hot during use, Are your speaker "Leads" "Big" enough? Is you Power Positive wire the same, Also as you say, Check your Earth. Sometimes a Fan on the output devices helps.
Mar 10, 2010 | Car Audio & Video
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
No LED power lights go on
the light with the power light(middle) is a blue/purple faint light try checking it out at night.The squiggy(as heat waves) will only light when the amps shuts down due to thermal protection(wait for it to cool). The bolt/yellow (short circuit) will light when there is an electrical overload in any of the wires(check +ve leads).
May 26, 2009 | MTX JackHammer JH202 Car Audio Amplifier
Harman Kardon HK 3380 Receiver Logo
93 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
