Question about Ktl Cctv CFB2056IR Black and White Infrared Weatherproof Camera, 450 Lines of Resolution & See Up To 80 CFB-2056IR, Cfb 2056IR, CFB2056
I have a home cctv camera and some onehas cut offthe end and i dnt knw wot colour goes were i have 3 wires red,black n brown and im sure red n black is pos n neg wich onli leavesthe brown to be videobt wen i applied 12v and wiredup the neg and video output i wernt getting noyhin but lines
The towing plug has been cut off. Trying to wire
in most red is stop ,yellow is left signal , green is right signal, brown or black is parking lights ,white is ground use a test light to comfirm what your doing , like turn left blinker on test wire and tempararly connect and so on ,be sure to hook up ground first. if you need more help just send a message in comment section at bottom
Oct 08, 2014 | Cars & Trucks
I have removed the element from my technika fan forced wall oven. Not sure which wire is the earth ? There are 3 wires. onehas two wires running to the terminal clip and the other two are single...
Simple the colour of the wire will give you the direction of their function what you need to know are the color of the wire.
However, if there is red wire among the two wires or( white or yellow) the white means and the red means power.
Good luck and then make sure that all electric power are disconnected .
Thanks for using fixya.
Jul 30, 2011 | Ovens
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
Fitting single towbar electrics, Hyundai Coupe 2.0 2004 (Tiburon)
Hi There. Im not sure where you are but this is the sequence for the UK< Hope it helps.
here are the 7 cable locations and pin numbers.
Pin 1 Yellow L/H Direction Indicator
Pin 2 Blue Rear Fog Lamps
Pin 3 White Earth Return
Pin 4 Green R/H Direction Indicator
Pin 5 Brown R/H Tail & No, Plate Light
Pin 6 Red Stop Lamps
Pin 7 Black L/H Tail & No, Plate Lights
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.(
Good Luck
Apr 16, 2010 | 2003 Hyundai Tiburon
Wire Colour coding for Behringer C1 Microphone
It is likely that the brown goes to pin 1 (ground/shield phantom -) as well as the black.
Red is likely to go to pin 2 (across from 1)(signal +)
and the orange to pin 3 (signal -)
Apr 15, 2010 | Behringer C-1 Microphone
I have a 230v electric extractor fan ,wires from motor are Black , Blue , yellow Wires from starter are Black , Blue . Wires from plug Brown , Blue , Yellow Wot wire goes to wot wire
Blacks to blacks and brown, blues to blues and yellows to yellows. Use a GFI on this unit! Always use caution! 230 volts tends to do more than tickle!
Feb 08, 2010 | Dryers
Hi. trying to re-install a pioneer deck where an alpine used to be. can't read the japanese on the alpine wiring to know which wire is for what. What coulour goes to the ignition, what colour is for the...
dnt get confused, follow these simple wiring .......
firstly cut off the old lug from the connected place, make sure you cut each wire seperatly....and you are going ti use the wiring agin, avoid making the wires shorter...
YELLOW..12V+ DIRECT FROM BATTERY...can be joined where alpine yellow was conected.
RED...12V+ IGNITION WIRE..can be joined where alpine red was connected
BLACK 12-, NEGATIVE....BODY GROUNDING
ALL SPEAKER WIRES HAVE +AND-, PURPLE/PURPLE----------WHITE /WHITE-------GREEN/GREEN.......GRAY/GRAY..ALL THESE ARE SPEAKER WIRES, COMPARE THE CONNECTION OF ALPINE AND FOLLOW THE COLOUR FROM APLINE LUG AND JOIN THE PIONEER LUG ....THEY HAVE BAISC COLOUR WIRE AND AHVE SAME TYPE CONNECTION..DO IT
Oct 30, 2009 | Alpine CDA-9851 CD Player
Hi i got a red green and black wire cable and I
Partial solution. Rob's clarification request is very valid, and you shouldn't mess with electrics if you are not completely sure what you're doing. That said, my guess is that you are in Europe (possibly the UK). Confusion can be caused by relatively recent changes in colour codes, so older and newer wires are coloured differently. Basically, red and brown signify "live", black and blue signify "neutral" and green signifies "earth" (or "ground"). So if you are just joining these cables, red goes to brown, and black goes to blue. But what about the green...?  Some machines are designed to be earthed, others are designed to be not-earthed, and it's not clear to me why you have an earth wire in one cable and not in the other. If the green is in the cable that brings power in to the machine, then it should be fixed to some metal part of the machine It can be FATALLY dangerous if you fail to earth a machine that should be be earthed. I repeat, if you are not absolutely sure what you are doing, don't risk it. Anyway, post more details and it looks like there's at least two of us out here who can help you.
Mar 05, 2009 | Electrolux Epic 6500 Vacuum
I need to know what color are for what on my radio wire harness
Not for sure if I can help.Someone forgot the golden rule.NEVER CUT THE WIRING HARNESS.I dont have the wiring scematics in front of me but the older models had RED for power,BLACK for ground,and the wiring going to the spreakers should be an off color running together going to the speakers.Probably has a six speaker system.Hope I helped.
Feb 03, 2009 | 1994 Chevrolet Camaro
Ktl Cctv CFB2056IR Black and White Infrared Weatherproof Camera, 450 Lines of Resolution & See Up To 80 CFB-2056IR, Cfb 2056IR, CFB2056 Logo
44 people viewed this question
Top Ktl Home Security Experts
Lawrence Oravetz
Are you a Ktl Home Security Expert? Answer questions, earn points and help others
