Question about Numark TT1650 Turntable
Motor not turning on numark tt1650 turntable
I push play on this direct drive numark tt1650 turntable and the platter/ motor is not turning!!!
djproaudio
  • 515 Answers
SOURCE: Numark TTX1 Turntable Problem-Platter stops
This is a drive issue. Unfortunately the TTX direct drive system isn't the greatest. It's good, but it's no Technics 1200. The only way to 'fix' this issue is to have a professional look at main circuit board to see if there are any components which are burned, or damaged in any way.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Posted on Nov 04, 2008
djproaudio
  • 515 Answers
SOURCE: Numark ttx turntable
More than likely the drive IC (integrated circuit) has shorted, and needs to be replaced. Not an easy fix, and you'll have to take it to a service center for replacement.
This is a common problem on this turntable.
- OPTiC
Turntable Repair Expert
Posted on Dec 13, 2008
djproaudio
  • 515 Answers
SOURCE: How do I remove the Numark TTX platter
Nope, nothing to it. The platter is just held down by gravity. Take a mallet or a piece of 2x4 block, and give the spindle a little whack. Not too hard, just enough to break the hold.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Posted on Jan 17, 2009
  • 16 Answers
SOURCE: HOW DO FIX MY NUMARK TTX MOTOR?
if you know how to solder its most likely the toshiba chip under the heat sink, here is more in depth, i wrote this up about 3 to 4 years ago
Ciscoel Nino - "since numark fixed thier overheating problems by adding avent under the platter, i think that what is happeing is that our DCMOTOR DRIVER IC (Toshiba TA7259P) has gone bad what i am going to do itorder this, install it and let you know the deal. there only 5.80 apiece and shipping is like 8 dollars. ill get back to you. I amguessing it is sort of like computers CPU, like its got thermal gel/grease on it and all that fun stuff. It is on the Motor's board heres the image
(IMG:http://img97.imageshack.us/img97/9139/ttx19tl.jpg)
after i install it too, i am also going to cut vents like this under my platter like the updated versions
(IMG:http://img97.imageshack.us/img97/8523/ttxvents8pn.jpg)
also take your time when installing the chip.
1. its sensitive to static.
2.buy a low heat soldering iron.
3.do each solder point at a time, wait a few seconds for the IC to cool off. then approach the next.
also open your ttx and see what exact IC you need. Mine was a Toshiba TA7259P. Also when you order that, order small tube of thermal paste.
http://www.audiolabga.com/ for parts ordering"
Posted on Aug 30, 2009
dunnbiker
  • 8546 Answers
SOURCE: Platter/motor won't turn
I don't know the answer, but you have written one of the finest, most comprehensive problem descriptions I have come across. In mechanical scenarios, that is priceless. I'm sure a turntable guru will see it and go, "aw. I know what that is". Good Luck.
Posted on Feb 15, 2010
How do I get my sound from my Numark TT1625 to play through my DVD/CD speakers?
You need a magnetic cartridge preamp. You then plug your turntable into it and the box into the CD/aux imput of your amp.
May 21, 2010 | Numark TT1650 Turntable
Numark x2 motor problem
I would like to know if it possible to use my Numark DXM09 mixer ... with two Numark ICDX players and use Numark Cue software
Oct 14, 2009 | Numark x2 Hybrid Turntable
Numark tt1625 turntable wavey sound
Your belt is probably worn and needs replacing. Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
May 28, 2009 | Numark BATTLE PAK v.4 Turntable
Second hand decks
The unit should not be making any sounds like that. It sounds like the timing is off for the gearing underneath the platter. It may be as simple as cleaning the existing grease on the mechanism and re-lubing. The existing grease may have gummed up a bit not allowing the parts to move freely. Take of the bottom and look at the condition of the grease.
Dan
Jan 27, 2009 | Numark TT1650 Turntable
I brought a set of second hand numark tt1650 and when you turn them on and get them spinning there is a small popping/clickng from underneith what could be wrong and is it serious
Dan
- OPTiC.
www.djprolab.com
Nov 04, 2008 | Numark TTX1 Turntable
Numark TT1650 Turntable Logo
152 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
