Question about Targus PAWM001U Mouse
Logitech batteries in wireless mouse dying daily
  • 35 Answers
Do you keep it turned on when you don't use your pc? Also try using it on a blank piece of paper
Posted on Sep 22, 2007
Mouse quit working
Logitech wireless mice operate in a slightly different technological sphere to wired mice.
Wireless mice need batteries, they need to be turned on and they need an interference-free radio environment.
One advantage of wireless mice is that they tend to function with laser or optical parts rather than a ball and wheels, so there are fewer moving parts to go wrong.
However, optical and laser wireless mice have considerations to take into account.
Change the batteries in the mouse if the mouse doesn't work.
Remove the battery cover and insert new batteries.
On the underside of the mouse could be plastic sticker with a phillips head screw (star) under it
Turn the Logitech wireless mouse on with the switch on the mouse.
Plug the USB receiver into a USB jack on the computer.
Try to use a free jack that's actually on the computer rather than one that's in a hub.
Test the jack first.
Try plugging in a printer and see if the printer is recognized--that way you know the USB jack is good.
USB jacks are notorious in that you frequently get a bad jack on a computer.
Turn off devices that are in the same frequency range as the mouse.
Logitech wireless mice operate at 2.4 GHz, which is in the same area as Wi-Fi routers and older cordless phones.
Start by turning those devices off and see if you can eliminate any causes of interference.
Test with wireless speakers too, then computer power supplies, monitors, cellular telephones and garage door openers.
Place the mouse on a flat surface that doesn't reflect. Avoid metal surfaces too.
Apr 21, 2013 | Logitech Cordless Mouse
How do you change the battery in the Mouse
model no. all the wireless mouses have battery partition at downside. check it
Mar 08, 2011 | Logitech Cordless Mouse
My Logitech mouse is wireless # CE0682 and the red light on the mouse is always flashing, even when on the receiver. I also have some problems when I want to use the mouse to hilight a block of text, as I...
Gina, I've had my Logitech ce 0682 for years and have had some similar problems. The mouse is supposed to rest in the cradle and recharge the batteries, but I've noticed that it rarely works for me. The connectors on the mouse seem to scuff and corrode easily and I'm sure that degrades its ability to charge batteries. So my solution was to buy a 4 pack of rayovac rechargable batteries(AA) and a usb battery charger. I never put my mouse in the cradle now and keep 2 batteries recharging at all times so I always have fresh batteries when that pesky red light comes up telling me the batteries are dying. As far as your highlighting text problem. Sorry don't have a solution on that one.
Sep 03, 2010 | Logitech Cordless Mouse
Logitech mouse frozen up we changed batterys in
If the mouse is freezing up though the batteries are fully charged, here's what you need to do:
1. Try to use different batteries just to make sure that it's not a power issue.
2. Connect the wireless USB dongle into different USB ports of the computer.
3. Try to connect the USB dongle in different computer and try to use the mouse (to make sure that it's not a computer issue).
4. Make sure that there's no cordless phone, cell phone and other wireless devices that might interfere the wireless signal.
The Logitech wireless mouse is running on 2.4MHz frequency, same frequency as the other wireless devices. Any wireless device might cause the mouse to freeze.
If same problem occur, then it's a hardware problem. Contact Logitech and RMA the mouse.
Thank you and good luck!
Apr 18, 2010 | Logitech Cordless Mouse
The battery has died in my mouse but I can't find a way to open it to replace the battery
Lock button on bottom of mouse, then the bak of the top will slide of for replacement of batteries
My logitech wireless usb mouse will not turn on at all. I have even changed the battery and still wont turn on. i made sure the batteries were in correctly and i just wont turn on. I was using it and it...
I'm having the same problem, connecting isn't the problem, its just that the mouse won't even respond to the batteries being put in. Bought fresh new batteries, still no luck :\
Sep 25, 2009 | Logitech Cordless Mouse
Logitech Corded optical mouse: ? batteries
If it is plugged in to your computer, it won't have batteries. Only wireless mice do.
I assume it's a Laser Mouse? If so, try plugging it in to a different USB port. Also try cleaning the laser, making sure it's clean of dust and dirt, also check the surface it's being used on as it doesn't work well on different surfaces! If it still doesn't work, then it's probably a hardware fault - chuck it out, time for a new one!
Hopefully I've been of some assistance!
Jul 02, 2009 | Logitech 9311570403 Mouse
Wireless optic mouse died suddenly.
This is either a problem with your wireless mouse usb detector, or simply the battery.
In most wireless mice, there should be screws at the bottom wher you can unscrew and replace the 2 small, circular batteries.
For the usb wireless detector, check it for any scratches and dents. If there are any, you will have to buy a new mouse.
Hope this helps and please rate!
Jun 18, 2009 | Logitech Cordless Mouse
Wireless mouse and keyboard
Batteries go flat within 10 days even if the mouse is turned off.
Sep 10, 2007 | Computers & Internet
Targus PAWM001U Mouse Logo
55 people viewed this question
Top Targus Computers & Internet Experts
J John
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
