Question about Sony DCR-HC52 Mini DV Camcorder
Cassette stuck; LCD blinking C:32:11
The camera is telling me to add a DV cassette, but there is already one in there. But, when I open the case to eject it, the tape will not pop out. It is also blinking on the LCD screen C:32:11.
Help
  • 883 Answers
SOURCE: removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Posted on Jun 06, 2007
philipp
  • 217 Answers
SOURCE: c:32:11 message flashes, cassette eject won't work, camera doesn't work
Defective mechanism,
a stucked mechanism is
present. camcorders are
smart. it can detect error
and shut down itself for
safety. earlier models
domino the defect if
the user is not quick
enough to react when
something goes wrong with
the camera. You need
professional service to
fix it.
Posted on Nov 25, 2007
  • 6 Answers
SOURCE: cassette loading - keeps on ejecting cassette
The "remove cassette" problem on Canon DV cameras is a general fault error that can be induced by many varied problems from faulty dew sensors to jammed mechanisms. These mechanisms are small and delicate and it does not take much to stop them working. If the head drum is starting the next thing that should happen is the capstan spins which in turn drives the take-up spools when the cassette loads. Tape tension problems (other than a broken tape) would not be detected until after the capstan is running. With the battery removed and the cassette door open, CAREFULLY attempt to rotate the capstan spindle. I use a small rubber insulating sleeve stretched over a small screwdriver. If this does not solve the problem then other possibilities are that the printed ribbon cable from the cassette mechanism to the camera needs re-seating or perhaps the capstan drive motor is faulty. However, try and look for the obvious first. To investigate further by dismantling is extremely difficult and I would not recommend it unless you want to risk writing-off your camera completely. I have done this operation (successfully) as a last resort and found that re-seating the printed cable in its socket solved the problem, however, I would not recommend or suggest this decision be entered into lightly. Its a good feeling when you get it working again but sickening when you have to allocate it to the re-cycle bin. As I say, this fault indication has many causes. Getting it serviced by Canon is not an option as the cost would exceed its value so unless you can find a local repairer that's prepared to look at it, then you have very few options.
Posted on Dec 18, 2007
SOURCE: loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Posted on May 06, 2009
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Posted on Jul 16, 2009
Cassette door will not stay shut
yep thats the camera telling you that its broken or that the tape is damaged
Nov 01, 2014 | Samsung VP-D103i Mini DV Digital Camcorder
Loading a cassette
having the same problem...when I put a new tape in it just ejects it right away!
Apr 17, 2008 | Canon ZR200 Mini DV Digital Camcorder
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Mini DV Cassette won't come out. Cassette case moves up and down but doesn't open.The display keep on saying Cassette is ejecting.I don't use it as often.
I AM HAVING THE SAME PROBLEM. HAVE NOT USED THE CAMCORDER FOR A YEAR AND A HALF. IT MECHANISM MOVES IN AND OUT BUT WILL NOT OPEN UP TO PUT A TAPE IN. VERY FRUSTRATING.
Feb 21, 2008 | Canon ZR65MC Mini DV Digital Camcorder
Cassette area
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it. Check your tapes carefully, most cause of this trouble are due to defective tapes, especially sony brand, I recommend you use TDK tapes.
never force open any unit, it will only make things worst!!! [;0)
Oct 02, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Problem with loading cassette
Sep 13, 2007 | Canon Optura 200MC Mini DV Digital...
Cassette stuck
I have the same problem eject cassette stuck on my brothers camera he gave it to me to bring home to try and fix for him how-ever not before his son tried to force it and damaged some of the casing that holds the cassette. I straighten it all out and then found that a very small spring at the back of the camera had come off which was stopping it from ejecting. Once I lifted this spring and hooked it back on that it now ejects no worries at all..
May 01, 2007 | Canon MVX250I Mini DV Digital Camcorder
Will Not Load Cassette
I have the zr850 which I have used less than a dozen times, and it does the same thing as you describe. Was told by canon tech people to try a maxell brand tape and a head cleaner tape. Have not tried their sugestion yet. camera is 3 months old.
Aug 07, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Sony DCR-HC52 Mini DV Camcorder Logo
264 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
