Question about Sony Cyber-Shot DSC-P52 Digital Camera
Shutter isn't opening...
When I turn the camera on there's a clicking noise at the shutter, which won't open all the way. Then a message appears saying turning camera off and on again. I do this, same thing happens. Camera is inoperable.
  • Anonymous May 24, 2009
    SHUTTER WILL NOT OPEN AND I CANT TAKE PICTURES
    Sergeant:
    Champion:
  • 289 Answers
Hi..For shutter problems,take it to the expert,don't mess with
it yourself. Take it to a real camera store, and they should
either be able to fix it there or recommend or send it off to
someone who can.
try ths out..
thank u..
rate me..
Posted on Apr 12, 2009
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
Can't take any photo with my Canon S3IS any more. The view finder and the screen is black when I try to take some photo but I am able to see all photo that is already on my memory card in the view finder...
Look into the lense while setting the shutter speed at a half second or so (slow enough for you to see the shutter open and close) and click the shutter release... you should see the shutter open and close. If you don't see this, then you may have a 'sticky shutter' resulting from lubricant seeping into the shutter/aperature mechanism and preventing the shutter from functioning as it should.(Common problem reported with the S2 and S3 cameras... and probably the S1 as well)
I have gotten my S3IS to take pictures by turning on the power, then opening the battery compartment door and reclosing it repeatedly until the shutter opens (from the power surge) and an image appears on the LCD.
After confirming the sticky shutter was indeed the problem, I pursued a more permanent fix.
Jan 30, 2011 | Canon PowerShot S3 IS Digital Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Error Message
Try to take off the battery and reset the camera. You can also try to remove the lens and check the mirror opening..see if there is some thing stuck there. You can try to click the shutter while the lens is removed. If this procedure didn't work I suggest calling Nikon for further repairs.
Sep 25, 2009 | Nikon D60 Digital Camera with 18-55mm lens
The LCD screen has gone blank...the other features seem to be fine...but can't click pictures any more...they appear black..
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 24, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
On the lens makes a clicking noise shutter goes in and out turns.
Did you drop it? if you did you have damaged the gear drive motor for it. Are the batteris good?
Jul 06, 2009 | Olympus FE-210 Digital Camera
Shutter won;t open
Are you talking about the shutter, or do you really mean the automatic lens cover ? Take a look at this first to see if this is what you meant. Make sure you read the comments also for additional tips. I don't think it will be necessary to open it up to fix it. Stick with the easy tips, they should work, especially if this is happening occassionally:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 05, 2009 | Canon PowerShot A570 IS Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Clicking noise and shutter wont open
Look for Contamination on the slide Take Denatured Alcahol and Clean the Assembely Let me Know ttech
Jul 20, 2007 | Nikon Coolpix 3200 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
351 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
