Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Need t know what the A, B, C switch on the Motorola ht1000 does
I need to know what the switch that is marked ABC, on the top near the volume control, does.
  • 14 Answers
ABC switch = Function switch
Can be programming to many functions like sub channel or talk group on trunking radio or scan on/off, power lo/hi, repeater/talk around...ect......depends on what software allowing you to do.
Posted on Apr 23, 2009
SYMA S107 Helicopter. Advertised as 3 channel. Remote has channel marking of A B C, but the switch is only 2 position. How do you achieve 3 channels with only 2 position switch?
This helicopter have 2 channels I see.
Maybe A-B is first position and B-C is secound position channel. Helicopter have not switch ABC, simply turn off and turn on for change channel.
Jan 14, 2011 | SYMA Toys industrial New Syma S107 Mini...
I have a HT1000 with a remote shoulder mic and a attached 3.5 listen only ear piece. How do I adjust down the volume of the identifier alert tone when I key up the mic. The volume control works for general...
In the programming software their is a field that allows you to either turn off the alert tones or make them lower then your volume level. Most of the time if any of my customers are using a ear bud or headset I turn off all of of the "beeps". Michael
Dec 02, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator: What is the toggle switch on the top of the Microp...
The toggle switch on the portable radio can be programed for different options like changing zones ( groups ) of radio channels.
It depends on how it is programed. A lot of times it is turned off in the program.
May 18, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
How to set channels to scan on motorola ht 1000
On the HT1000, there is an A, B, C toggle switch just under the On/OFF/Volume control knob.
When set to A, the radio is IN the scan mode.
When set to B it is NOT in the scan mode.
When switched to C, it is in the scan program mode. There is a green button on the left side above the PTT switch. When you set it to C, you switch the CHANNEL SELECT knob to the desired freq you want to add to the scan list. When there, you push the green button. ONE push gives you a red indicator light on the top of the radio. A 2nd push gives you a GREEN light displayed. A 3rd push gives you NOTHING lit up.
The 1st push (RED light) means you have selected THIS freq as your PRIORITY channel of your scan list when scanning.
The 2nd push (GREEN light) means it is just IN the list, not as a priority channel.
NO light means it is NOT entered into the scan list.
Once you have your list set up, simply flip the A,B,C switch back up to A and you're scanning what you selected.
HOWEVER All of the above is dependent on whether or not the ORIGINAL setup programming from the factory set the radio up for these features to work. If it WASN'T set up that way, you'll have to have it reprogrammed to activate the buttons and the toggle switch for those features to work.
Jan 27, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
I have a mts2000 two-way radio that i can't program how can i fin
1 program the ABC switch as zone select,
2 program each peersonality into proper zone (eg A1,A2...B1,B2...C1...C2...etc)
3 load the code plug into the radio.
Apr 01, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
User manual for Motorola GP 900 2 way radio
No user manual available, GP900 is a European version of HT1000 here in the US. Basically, on the top of radio on/off volume control is on the left, next to it is a channel selector, 3 position ABC toggle switch and orange button for emergency. On a side are button 1,2,3 and PTT switch. Hope that will help.
radcom907
Mar 07, 2009 | Radio Communications
I dont know how to program
1. Program the ABC switch as zone select.
2. Program each 'personality' into the proper zone (eg A1, A2..., B1, B2..., C1, C2..., etc)
3. Load the codeplug into the radio.
May 27, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
How to prograqm a motorola mts 2000 flashport?
HT1000
Hi bonkuman,
To my knowledge the Motorola HT1000 is not a trunk system radio, it is as a "conventional" 16 channels two-way radio. Motorola classifies this radio as intended for Government & Enterprise. In my country, we call them "Commercial" radios as oppose to "Amateur" radios. In a way, yes they may be termed "professional" as their claimed performance and durability exceeds those of other radios. Incidentally, the Motorola HT1000 has been discontinued and was replaced with the PR1500.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 27, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
How to Program a Motorola HT1000: Hex?
To program this radios you need the RSS, RIB box, and the programming cable.
The Hex Editor is used to modify the RSS for some specific functions beyond the programming.
The RSS you need is the RVN4098 try to search in the web.
Mar 09, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
606 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
