Question about Sony CDX-S2010 CD Player
Demo mode the demo mode is stuck on i went through the steps turning it off but when i turn off the car everything resets what do i need are what do i do
  • 98 Answers
Re: demo mode
Hi... your radio has 2 power wires. One is red and the other is yellow. Check for power on both of these wires with the key on. If both have power then you probhably have them switched around!! (one is constant power for memory to "remember" the settings, the other is key on power to that the radio knows the ignition key is on or off. From the sounds of what you are describing it sounds to me like you have your wires switched around...
Posted on Sep 13, 2007
0 characters
3 Points
How to turn demo mode off on Blaupunkt MP46 ?
go to settings and then in display find demo and turn it off there.
Apr 24, 2014 | Blaupunkt Bahamas MP46 CD Player
On my pioneer p6500 it is stuck on demo mode how do I turn this off so my radio will work
You should still be able to turn the radio on even if it is in demo mode. If you can''t turn the radio on, you have other problems. Did you try pressing the source button? Most pioneer radios tell you how to turn demo mode off when you first put power to it.
Apr 12, 2012 | Pioneer Car Audio Receivers
My AIWA cd-x444 unit is stuck in some kind of dealer demo mode, and not the demo mode that you can program the unit to enter from the menu. In this mode, whenever the unit is on, it flashes through all of...
it sounds to me like you may have a bad switch. sometimes if you get a switch that does not open all of the way, it sends a message to the microprocessor and locks it up. when this happens, the switch needs to be replaced.
Mar 10, 2011 | Aiwa CDC-X444 CD Player
Cab't turn the bloody display mode off!!!
from what i understand it is called "demo mode".
To turn it off follow these steps:
1. Hold the Sel button till the display shows "demo" Then turn the volume knob until the display reads "demo off"!
Done :D
Hope this helped and if it didn't please give me more detail as to the problem...
Nov 23, 2010 | JVC KD-G140 Car CD Player
Demo Mode JVC KD-G333 head unit
Hi guys, I had this problem and i just found a solution.
I was on FM mode when i tried this:
Hold down "sel" until the display says "demo"
Turn the volume knob and the display will toggle between "demo on" and "demo off"
I went back to CD mode and the blasted demos no longer appear!
Jun 21, 2008 | Car Audio Receivers
Demo mode
on my sportster 5 I held down Menu and Display together for 5 seconds to unlock the demo mode
Apr 09, 2008 | Kenwood KDC-MP335 CD Player
CDC-X304 in permanent DEMO mode
Jan 16, 2008 | Aiwa CDC-X304 CD Player
Unable to turn off DEMO MODE
1. Turn Radio On
2. Change Source input to Stand-By
( Puts radio in display only Stand By mode.)
3. Press Menu Button
( Gives you standby menu)
4. Toggle display with control knob until DEMO ON appears
5. Hold control knob in until DEM0 OFF appears
6. Press Menu Button
7. Change source back to music.
All done. same as other Fixes - Just step by step!
Sep 09, 2007 | Kenwood KDC-MP435U CD Player
Cant turn off the demo mode
There is often confusion in the way the manual states how to achieve removing demo mode. Because this is listed in the "Menu System" section of the manual and assumes you read from page 1 of the manual that you will know to enter the menu in this section of the manual. Here is step by step instructions on removing demo mode on your unit. 1. Go to standby mode 2. Press and hold the menu button till the menu comes up 3. Press control knob towards AM or FM to scroll through menu till you locate "Demo On" 4. Press control knob straight in for approximately 3 seconds till it switches to "Demo Off" 5. Hit menu button again to exit menu
Apr 05, 2007 | Kenwood KDC-MP732 CD Player
Sony CDX-S2010 CD Player Logo
479 people viewed this question
Top Sony Car Audio Receivers Experts
Larry Stiles
Larry Stiles
xxxxxx xxx
Are you a Sony Car Audio Receiver Expert? Answer questions, earn points and help others
