Error code 222 on a Linde H25 forklift typically indicates a problem with the lift's hydraulic system. This could be caused by a variety of issues, such as a malfunctioning pump, a faulty valve, or a leak in the hydraulic system.
You can try this:
- Check for any visible leaks or damage to the hydraulic lines or components.
- Check the hydraulic fluid levels and make sure they are at the proper level.
- Check the operation of the lift's controls and make sure they are functioning properly.
- Check the operation of the lift's safety features and make sure they are not activated.
- If the problem persists, you may need to call a professional forklift repair technician to diagnose and fix the issue. They will be able to determine the root cause of the error code and provide the necessary repairs.
