Question about Conair Professional Ceramic Hair Straightener - Black
Ceramic plates of conair infinity straightener do not get hot
I am located in Dubai, UAE. During our visit to USA we had purchased one Conair straightner model Infiniti Conair CS 31. Now the problem is the ceramic plates remain cold and do not get hot at all. This despite the fact the straightener is on power which is indicated by the green light. The green light indicator is on only at power level and at other heat levels only yellow light indicator is on. Please confirm the fact that we need to use convertor since normal electricity voltage in Dubai is 240 while the appliance specifications indicates it can be operated on only 120 volt power. Please let us have the address of Conair service center / agent nearest to Dubai . Thanking you
2 Suggested Answers
geokohler
  • 304 Answers
SOURCE: Straightener not working!!!!
It sounds to me like the thermal cutoff switch has blown. Straighteners have these as a safety device similar to a fuse to protect against fire in the event it gets too hot. These are not very costly to replace. Here is a link to where you can buy them and what they look like:
http://www.welco.com.cn/?gclid=CJiWv7TN2ZQCFQpzHgodl1LXQQ
Make sure you get one of the exact same cutoff point as the one designed for yours. If you put in a higher temp device it will be harder to blow but will make it dangerous as it may cause a fire if it over heats. Some shady repair men will just bypass this and it will work again fine but this is a dangerous practice as it directly puts you of danger. If you do have it repaired at a shop demand for the old thermal cutoff from your unit when you drop it off so the tech will know you know what is wrong with it and that you will check to make sure that it has really been changed. This will also not give him the chance to over charge you when he knows you know it is only a 1 dollar part and easy to change.
This device is very easy to change, If you can open your unit you could easily do this yourself. The part, as you will see on the site where you buy them, only has 2 wires one coming out of each end. You simply cut out the old 1 and replace it with the new one. You do not even have to worry which end goes where. It is like a fuse, it works the same either direction. You have to buy some wire crimp connector to connect it, you can not just solder it in due to the heat in the iron. In a pinch you could just securely twist the ends of the leads with the leads from the old cutoff if you clip the leads from the old cutoff real close to the device. This will leave you with plenty of wire to get a good twist. I always use the crimp connectors so it looks more professional.
Anyway, I hope you found this to be helpful and if you need more help feel free to ask me. I will stay with you on this until we have it fixed.
George
Posted on Jul 25, 2008
How can i fix the cord from my conair
Small Appliance Repair shop may be able to help, but probably best and more economical to just replace. If money is a factor to replace, check local thrift stores for a used one.
Sep 24, 2013 | Conair Professional Ceramic Hair...
I just got my Infinity by conair model cs32 straightener and it will not turn on or heat up. Please help.
If you just purchased it today or up to 30 days after purchase, TAKE IT BACK!!. If you start having problems from the beginning you will possibly always have them.
Sep 14, 2011 | Conair Infiniti Instant Heat Ceramic Hair...
My conair infinityhair straightener just stopped heating up.it turns on but it dosent heat up.
This is a job for one with a multimeter and soldering iron. Remove the temperature knob and the plate below that. It will expose the inside of the top half of the Straightener. You will see two set of red and black wires soldered to a green circuit board. See if the soldering are intact and no wire has come loose . Now unsolder the red wires ( please note which wire goes where ). With the multimeter in the Ohms range ( X100 ) touch the probes on the red and black wires each and check for continuity. The red and black wires are two ends of the ceramic heaters. If they have failed , replace .
Mar 07, 2011 | Conair Professional Ceramic Hair...
My Conair Proshine Straightner won't warm up, although the light is on. How do I fix this? ... hot plates not heating and the light says its warming up but the hot plates won't heat up
Most heated hair appliances are protected by a thermistor that will fail if overheated. These are small, about 1/2" long, cylindrical in shape with a pointy end and a wire coming from each end. When they go bad, they do not conduct electricity (zero ohms on a meter). There is a three digit number on the side that is the shutoff temperature. You can get these at Radio Shack.
Don't bypass this safety device.
Jan 07, 2011 | Conair Professional Ceramic Hair...
Moded cs327 wont turn on any more
FIRST CHECK PLUG FUSE HAS NOT BLOWN , THEN CHECK ELECTRICAL WIRE FOR ANY BURNS OR BREAKS.
Oct 27, 2009 | Conair Infiniti Instant Heat Ceramic Hair...
My conair straightener won't heat up
that same thing is happening to me! but iv had mine for almost 2 years...exact same hair straightener, its happening to many people! i dont know if this is the problem but alot of people wrap their cords around their straighteners (i did too) and it twists the cord that conects to the hair straightener and makes it loose. i still have not found a way to solve this problem.
i would just go out and buy a new one, and if your looking for good but inexpensive i suggest vidal sassoon. they get really hot and have many settings and many different types. mine has worked greats
just remember not to wrap the cord
May 31, 2009 | Conair Professional Ceramic Hair...
Power chord frayed and I need a new one for a conair hair iron CS36. The chord pivots in the handle 360 degrees.
go to (www.fixit.com/small apliance)
what I found out with my hair dryer (conair infinity model) was that there was a short at the plug and when I bent the wire a little to left or right the dryer would work. The plug is GFI protected that means there is a test and reset switch built in to the plug. There for for me to fix my hair dryer I would have to replace purchase order the whole cord. The cord assembly cost almost half the price it would cost to replace the dryer with a new dryer. I purchased a new dryer.
Dec 26, 2008 | Conair Dry 'N Straight Hair Dryer and...
Conair Professional Ceramic Hair Straightener - Black Logo
261 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
