Unable to switch on
I'm unable to switch on my vaio cr34gn laptop, I bought it 6 months ago. this problem occurs even if its connected to ac supply.
I fear if the motherboard crashed
  • Anonymous Apr 15, 2009
    it does not respond at all.
  • ultimitloozr May 11, 2010
    Does it do anything at all? Beeps? Color change on the screen? Lights on the unit?
Troubleshoot no power supply even the charger is connected
What to Do if Your Laptop Is Plugged In but Not Charging ...
www.pcmag.com > Reviews > Laptops & Notebooks
PC MagazineAnd no battery charging. ... but some problems may require a visit to a repair shop oreven a full-blown ... Get ready, boys and girls, it's time to go troubleshooting. ...Check the AC adapter brick and verify that any removable cords are fully ...
Laptop Won't Power On - Troubleshooting a AC/DC Adapter ...
www.ifitjams.com/lappower.htm
Troubleshooting problems where the laptop won't power, adapter LED is off ... When your laptop won't turn on with the AC power adapter plugged in, many ... SOme laptops even feature a power button that lights when the power is turned on.
Sony VAIO® - Some troubleshooting steps to help you if ...
? 2:56
https://www.youtube.com/watch?v=IsbMD-Ddcp0
Feb 3, 2012 - Uploaded by SonyListens
Sony VAIO® - Some troubleshooting steps to help you if your VAIO will not power on. SonyListens ..... I have a VAIO laptop & the AC adapter isn't charging the battery. Help? Oh yeah ... It's as if it isn't even plugged in. I've tried ...
Laptop Won't Come On Even When Connecte
Dec 30, 2015 | Computers & Internet
Blank Screen Sonly VAIO Tap 20
Is there a flashing cursor in the top left hand side of your monitor?
Aug 12, 2013 | Sony Vaio Tap 20
Hi. i got a dell inspiron n4010 laptop. my battery backup suddenly dropped to half. i bought the laptop just 25 days ago. what may be its cause?
I am glad to HELP YOU!
The problem that are you describing here occurs many times - even for the BRAND NEW laptops!
The RAPID DRAINAGE of the batteries can have multiple causes:
# a defective battery
# the humidity of the storage place
# a bad connector
and so on.
What I'd suggest you is to take back your machine to the store and to ask for a BATTERY REPLACEMENT. I assume that if you said you've bought your Dell 25 days ago it should be under some WARRANTY CONDITIONS...
The next battery you will gt do like this:
# attach the battery into its slot
# make sure your Dell machine is OFF
# connect the AC power supply into the wall plug
# with the machine still OFF let the battery fully charge for AT LEAST 16 HOURS.
My best regards!
... and don't forget to RATE, please...
useful WINDOWS TIPS!
May 02, 2011 | Dell Inspiron N4010 Notebook
I have a toshiba Satellite c655. I bought it for my 12 year old daughter about 6 months ago. she was using the internet everyday and then about a week ago it wouldnt connect to my router. The laptop...
IS THE CONFIGURATION OF SECURITY ON TOSHIBA WIRELESS ADAPTER SET TO WEP INSTEAD OF WPA OR VISA A VERSA CHECK THE SETTINGS ON YOUR OTHER LAPTOPS TO SEE IF THEY'RE THE SAME
Jan 21, 2011 | Toshiba Satellite C655S5056 Notebook PC
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
Bought 6 months ago and will not boot up, with battrey out it will attempt to start for a couple of secs and then nothing
After 8 days of no life at all in the laptop , having 2 computer technicians around saying it was probably the motherboard and just about to send to Sony I pressed the power button and hey presto it worked again..Guess it was just sleeping or hibernating...after all it is spring now....Actually one guy of the many forums I have visited advised just to leave the Laptop alone and perhaps it would mend itself..and hey presto he was right, although having said that I have yet to turn the laptop off and startup again..HMMMMMMM...
Apr 14, 2009 | Sony VAIO VGN-FS630/W Notebook
VAIO Notebook VGN-FS742/W is not booting
sorry to let you know sounds like hard drive is shot.........
Jan 05, 2009 | Sony VAIO VGN-FS742/W Notebook
Toshiba Satellite M65-S909 laptop will not start
Based on the problem you have described it could be one of many issues as to what is causing the problems. I know that answer doesn't help but need to be up front with you and not list all the possible issues. What I can tell you is that our company would be able to diagosis the problem once at our nationwide repair garage. If your interested in using our company check out our company website at www.LaptopGuy.com. Take a look at the testimonal section to see that we do quality work. I
Jun 01, 2008 | Computers & Internet
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
David Payne
David Payne
