Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error code 32 on a brand new kenmore HE 3T wash machine
  • 15,935 Answers
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
I have a Kenmore Front Load Washing machine and I am getting an error message f-35. what does that mean? It is an HE 3T Steam. Once I get this error code, the unit stops and unlocks.
This washer seems to have multiple solutions for the f35 error,
Unplug the machine for an hour to reset the computer
Clean the filter The panel below the door has 3 screws (mine was a star shaped screw). The white cap screws off. yopu may have to cancell the error using "stop".
Please Vote !!
May 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he 3t gets a code t
Hi
Thanks for using FixYa and Thank You for accepting the previous solution. However, please describe the complete error that you can view on your Kenmore elite HE3t so that I can assist you.
Thanks Rylee
Apr 11, 2010 | Washing Machines
Kenmore elite he14. What is the f14 error?
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Feb 18, 2010 | Kenmore Elite 45986 Front Load Washer
The door won't open. There are no error codes displayed. I have a Kenmore Elite HE 3t.
open the bottom panel by unscrewing 3 screws. reach up towards the door lock and pull a level to manually unlock the door.
Aug 17, 2009 | Kenmore Washing Machines
He 3t error code f6,washer will not spin,door will not open
"f6" error code means that there a miss communication between mcu(motor speed control board) and ccu(central control unit). i recommend you to ohm out the motor. most likely its your motor speed control located at the bottom left of the washer good luck. replace the motor speed control board and you should be all set to go.
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error codes f and h
I have the HE 3t and an error code of f flashes at the 9 minute mark. Can any one help with this problem? When I contacted customer service that told me to unplug the machine and plug it back in. This did not solve the problem. Any suggestions?? Thanks, Paula
Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE 3t - error code F dU and door is locked
Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
114 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
