Question about Gaggia Titanium Espresso Machine
Gaggia Titaminu The grinder spins and spins on my Gaggia Titanimu but doesn't seem to be grinding the coffee. It then keeps telling me that the bean holder is empty.
  • Sucram Sep 13, 2007
    I can not see that any screws are loose. The strange thing is that when I have done a full clean of the grinding unit and the "pipe" from the grinder to the brewing unit I am able to get 3-4 cups of espresso before it gives up again.
  • flyier Dec 21, 2007
    Hi Guys, I have the same problem - Grinder keeps spinning. The machine is about 17 months old. I cleaned out the grinder with a Hoover to no avail, Still getting the 'coffee beans empty' msg.
Same problem here for the Gaggia Titanium, which i resolved by first unplugging the machine, remove two screws up and behind the water tank. Lift the top and slide toward the back. There is a round rubber gasket between the removed top and grinder, be sure to reposition it as was upon reassembly. Now get out the hose attachment for your vaccum and with the crevice attachment in the grinder **** it clean. Also, cleaned up loose debre fallen into the works below the grinder. Reassemble. Seems as posted previously that cleaning does the trick. Why not vacuum? Worked for me.
Posted on May 22, 2008
  • Gaggia Expert
  • 109 Answers
I have had several machines with this fault replacing the microswitch under the dumper solenoid usually solves the problem.
Part number 186701200
Posted on Jan 31, 2008
Hello all,
I finally took my Gaggia Titanium to an authorized retailer. He cleaned it out and reset the grinder and settings. He told me that one common problem with fully automatic machines like this one is that they can't handle the very finest settings on the grinder, ie what you need to make a good espresso. I have now resolved to using a stand alone grinder for the finest espresso grind and just using the Gaggia grinder for lattes etc.
Sucks but seems that this is the only way!
Sucram
Posted on Jan 05, 2008
    Problem Solver:
  • 7 Answers
You may have resolved this by now but, sometimes the simple solution is the right one! The chute on this (and other) superautomatic does not like the oily residue that beans inevitably leave. All it takes it gently putting one or two fingers into the bean hopper as the grinder motor starts to sound louder/faster (this is caused by the grinder motor being under less load/strain because no beans are feeding) and wiggling for 1-2 seconds. If you do this immediately after hearing the grinder motor's rpms increase you will not get the "fill bean hopper" error message. No hard pushing is required, just a gentle wiggle. There is a shroud over the actual bottom of the hopper, so you don't want to stick your fingers beyond that. If you are concerned about actually sticking your fingers into the hopper while the grinder is running, you can simply push down on the top of the beans with gentle pressure which will in effect force the beans down and accomplish the same thing. This technique + regular cleaning of the grinder is all you need. wholelattelove.com has detailed instructions on cleaning the grinder (Gaggia Titanium SS) on their site. Hope this helps! Tony
Posted on Jan 04, 2008
HI, I am currently having the exact problem, the grinder seems to just spin & I keep getting a msg sating that it is out of beans. Bought it a year ago, so it should be still under warrenty hopefully.
Posted on Oct 07, 2007
  • 625 Answers
Check to make sure the blades are secured to the motor shaft. some have a set screw, some are positioned over a pin in the motor shaft.
Posted on Sep 11, 2007
6ya staff
SOURCE:
My Gaggia Unica won't grind the coffee beans, it just whirs and stops making the drink
More than likely the machine is stuffed with coffee grind. Need to take it apart and clean it. See https://www.youtube.com/watch?v=JQbP2v8C-sA
Sep 20, 2014 | Gaggia Unica Bean To Cup Coffee Machine
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
How do you adjust the size of grind with a gaggia grinder
The is a little lever you push up by the bean hopper. Then rotate the bean hopper to change the grind.
Apr 20, 2010 | Gaggia MDF Electric Burr Grinder
I have a gaggia syncrony logic.The coffee beans are not going to the grinder so the grinder is just spinning,we have cleaned the machine and cant tell if something is stuck in it or what. cand you help?
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Oct 27, 2009 | Coffee Makers & Espresso Machines
Gaggia machine sounds as if it keeps grinding but no beans are getting through the grinder. I have cleaned machine completely, emptied the beans, opened the grinder to the biggest setting and still no...
The grounds chamber/gate might be blocked you will have to clear it out. Remove brew unit and find discharge for grinder, then push gate back and clean.
Aug 25, 2009 | Gaggia Syncrony Espresso Machine
Grinder spins but won't grind coffee
You have fill a water in your coffee grin
Jun 19, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
1,016 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
