Question about Indesit W 123 Front Load Washer
W133 Indesit program dial keeps spinning.
I have got a W133 Indesit washing machine but the program dial just keeps going round.
kjmac
  • 97 Answers
SOURCE: INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Posted on Aug 06, 2008
  • 641 Answers
SOURCE: dial clicks round
Open the rear panel and look for a broken or worn belt. If this is the problem you can replace it easily. Good luck !
Posted on Jun 16, 2006
  • 1294 Answers
SOURCE: Indesit W101 Washing Machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 31, 2007
SOURCE: indesit w113 fills with water and then dial just spins to number 9
test the element
Posted on Jan 15, 2008
SOURCE: indesit wm2x
We had similar fault.
Rectified ours by switching off at the mains and put dial to one of the dots. Switched on and it reset.
Good luck
Posted on Dec 08, 2008
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
My washing machine has just decided to stop before spinning and the dial continues to click round and round and round... Its still full of water...... What do i do?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Indesit Washing Machines
The dial stops on 2 will not spin or empty when switched manually it move round like a second clock through the programes. I have had the pcb. board checked by post with Q E R and they say its ok.INDESIT...
hello any spin problem can be down to the module board the fact you've had turn the dial which is the programmer sound like this is the fault if this is the case you may need to be looking for new washer. sorry to be negative i hope you find a solution
regards
shaun
Feb 28, 2010 | Indesit W 123 Front Load Washer
Indesit w93 is not rinsing,
this is most likley to be the programer brain its gone fulty on you,, its not a cheep part to get fixed sorry
Oct 26, 2009 | Washing Machines
Indesit programmer has a mind of its own
I have LG Washing Machine WF-S6607 when I START after 5 Second it will be stop and alarm to come up on Rinse MODE. what I do?
Oct 17, 2009 | Washing Machines
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
INDESIT WI101
hiya
hope this helps
Aug 04, 2008 | Indesit W 123 Front Load Washer
Indesit w143uk
these machines are a problem! the dial clicking round can be a component fault - ie pump etc - or a module fault. from what you describe, fault could be with the pump. an easy way to check is to power the pump up independently and see if drain works ok. (i assume you have checked the filter) after that, check continuity in the heater as well. if both of these are ok, you are faced with a module fault
Jul 21, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
218 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
