Question about Hannspree HANNSball.champion 15 in. LCD Television
When hooked up to cable -- comcast I believe no color
Just black and white not sure what is wrong of if repairable.
0 characters
1 Points
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Flat Panel Televisions
I hooked up my ps3 and the picture comes in and its in black and white?
Are you using component input on your TV, RGB? or Single RCA?
Sep 25, 2014 | RCA L32HD31 32 in. LCD HDTV
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Flat Panel Televisions
I need instructions on hookup to Comcast Cable
I'm sure Comcast will be more then happy to direct you on phone step by step on how to do this... I'm sure you pay them every month.. don't you.
Best way I'd hook up is through the 5 RCA jacks monster cable.
3 for picture... green red and blue. then the 2 red and white for sound. match colors cable box TV.
if asking to connect direct cable to box.. your tv will pick up either some or nothing. you still need the Comcast cable box.
Jun 02, 2013 | Philips 20PF5120 20 in. EDTV-Ready LCD...
My little 15
If the format of color system such as PAL/SECAM etc. is not same as that of telecast, you will get picture in black and white.
Aug 04, 2012 | Coby TFTV1503 15 in. LCD Television
Components are in black and white instead of color
Wrong connection. Hook up the component output from DVD player or Wii to TV component input using component cable(red, green and blue plug)
Dec 29, 2009 | LG Flat Panel Televisions
Panasonic TH-42PD25 The picture is black with
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
Oct 28, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
Hannspree HANNSball.champion 15 in. LCD Television Logo
358 people viewed this question
Top Hannspree Flat Panel Televisions Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Hannspree Flat Panel Television Expert? Answer questions, earn points and help others
