Question about Philips 32PF7321D 32 in. LCD Television
TV locked into 1 channel ... does not respond to any inputs
Actually is a 32PFL 7623D / 10 ...Has always been slow in response to inputs, learned not yo overload input by multiple commands (usually in frustration) ,,, recently downloaded software upgrade from Philips site ... now will only show one channel at fixed volume etc. ... no input works either from remote (batteries changed) nor from set located buttons ... occasionally will respond to switch off, but then restarts spontaneously after about 15 seconds ... to the same channel. set is approx 5 months old (so will be going back to supplier I think) ... any ideas what might cause this ... or are these machines just too damn clever for their own good?
  • 4 Answers
SOURCE: Actually Philips 20PF5320/01 Fault no power, blinking LED
If the TV has sound and no picture, it might be the timer settings. There is a fix for Philips 20PF5320 here
http://www.123datarecovery.co.uk/fix_philips_pf5320.htm
Posted on Mar 20, 2008
SOURCE: Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
  • 44 Answers
SOURCE: Philips 42PF7220A/37B shuts after 10-15 min. LED Blinks 5 times
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 178 Answers
SOURCE: Screen stock on Software Upgrade Application
First of all the software update may not have been done yet, when tv's go through an update (depending on which update) the set can turn it's self off and seem to be done, but you need to wait it out and the set will turn it's self back on, Wait it out for about 30 minutes before doing anything. be paitent. UNPLUGGING THE SET CAN DAMMAGE THE TV DURRING A SOFTWARE UPGRADE!!!
If after a LONG period of time try unplugging the set and re-setting the micro. But only as a last resort!
If the upgrad failed and you can't get the set to function properly you need to change the ssb board. If the set is in waranty, waranty should cover this.
Posted on Sep 03, 2009
Apps not responding an running very slow
Everything is suddenly slow or is not responding. - Windows 8 Forums
www.eightforums.com > ... > Performance & Maintenance
Jun 24, 2014 - 10 posts - ‎2 authors
... year old and it started to load everything really slowly or is not responding for ... of memory to run Windows 8 efficiently so that isn't the problem. ... (It's not always showing, that the application is not responding, when it froze).
Solved: system is extremely slow and everything is "not responding ...
forums.techguy.org > Forums > Operating Systems > Windows 7
Sep 13, 2013 - Solved: system is extremely slow and everything is "not responding" ... Only after several minutes do the programs become responsive again, but once I try ... If using Vista or Win 7 - right click the icon - run as Administrator
iMac very slow, apps not responding, wheel turning ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 28, 2012 - iMac very slow, apps not responding, wheel turning ... (Expect it to take longer to start this way because it runs a directory check first.). Mac runs super slow and apps not responding
Apr 23, 2015
running very slow and apps not responding
Sep 20, 2013
Macbook running slow and all applications stop responding - Apple ...
Jul 29, 2012
Running slow, Not responding
Oct 10, 2011
More results from discussions.apple.com
Jan 06, 2016 | Tablets & eReaders
I have a 32PFL 7403D/10 tv-does it support Hd & why can I only get 41 freeview channels?
you must contact the supplier cable for support via ONLINE chat, and ask them about your problem. However you must go to MENU, and add the channels that you are missing, and follow the instruction in your owner manual or download free from www. retrevo.com
God bless you
Dec 06, 2013 | Televison & Video
Philips tv problems
you must reset the MENU, and add the channels that your are missing. 2) However you must ask to your company supplier from cables about this problem, ge the support via ONLINE chat with them for fix it.
God bless you
Acer extenza 5620z mouse not responding as it should keyboard input slow and not responsive cannot input all digits of my password to get computer started
How long since you've run the computer? Might it be processing and update like when it reboots after installing a service pack? That might be making the computer run slow for a few minutes. Give it a little time to get started and see if your mouse and keyboard begin to work.
Jun 01, 2009 | Acer Extensa 5620-4020 Notebook
My samsung tv is not responding to my remote control, actually even when I go and attempt to change the channel from pressing the up/down buttons on the tv it won't respons, some menu screen would come on...
your turning section is not responding to any input, hence needs to be checked by a technician. every thing you have mentioned are controlled by one ic, with its respective voltages.
Mar 21, 2009 | Samsung Remote Control
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Sep 11, 2007 | Sharp 27K-S100 TV
Open Questions:
Philips 32PF7321D 32 in. LCD Television Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
