Question about Marantz SR-82 Mark II Receiver
Hi there. I have a Marantz SR-82 Receiver that makes a clicking sound and stops working then clicks again and starts working and continues like this until I get so annoyed I turn it off, But lately it doesn't allow any sound from the speakers at all. Can't even get the am/fm to make any sound thru the speakers. Any ideas fellas?
Hi, try to turn down the input balance knob, I think you have overloadet it.
Posted on Mar 19, 2010
  • friendwer Mar 19, 2010
    I think it is a very good reciever, it really really sounds clean, balansed and natural. Same quality as good Marantz amps. So take care of your unit :)
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
Marantz problems
my sound on my marantz av surround receiver sr5003 stopped working, i need help to restore it:
Jan 01, 2014 | Televison & Video
Marantz sr5600 reciever click and goes to blinking standby
I have the same problem. Earlier it got sorted out itself and now it has started coming up again.
Feb 26, 2012 | Marantz SR-5600 Receiver
I have a Marantz SR7200. I have been using for a long time with 6ch stereo with no problem. Suddenly, it starts to make a lot of noise on front speakers in any mode. It just stops this noise when source...
Hello Sergio.
Sounds like a bare wire (speaker wire) most probably is touching your SR's metal body.
Remove all speaker cables, re-terminate them clean (cut, trim, and twist again) and then re-plug them in to the binding posts.
When you go puredirect, it overcoms some filtering circuits of the board and this should be the reason why it stops.
Try that & advise.
Dec 13, 2010 | Marantz SR-7200 Receiver
What would work better for Marantz SR 4200 Apple Composite or component cable? In order to play music through the amp as well as watching videos
Component Video is a big step up the food chain in quality. Component Video inputs are for video only, not for audio. I don't see Component Video inputs on the Marantz SR-4200; only Composite and S-Video. S-video would be a step up from Composite and it carries analog stereo sound.
You don't give any clues as to the source's audio capabilities.
Digital Audio of either flavor is preferable. Grab the best possible TV-related audio from your Cable/Satellite box to the Marantz and run a pair of RCA audio cables to your TV just in case you want to watch the weather channel without hi-fi sound.
Mar 18, 2010 | Marantz SR-4200 Receiver
Marantz SR82 Turn on but secondary circuit does not powerup
Its worth to fix it. I think it is a best reciever for a price, it really really sounds clean, balansed and natural. Same quality as good Marantz amps.
Aug 04, 2009 | Marantz SR-82 Mark II Receiver
Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
May 31, 2009 | Marantz SR-19 Receiver
Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Feb 11, 2009 | Marantz SR-5200 Receiver
Marantz Sr8500
Check the speakers impedance. it should be greater then 6ohm otherwise you overload the system. Also, if the speaker sytem is rated (in Watts) below the amplifier's power it overloads the amp at higher volumes.
Apr 12, 2008 | Marantz SR8500 Receiver
494 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
