Question about Dell Computers & Internet
Server just stops!
With increasing frequency our server just stops. It has power, all the lights are on and show a 'good' status. However, everything is frozen, screen goes to 'sleep' and clients systems cannot access shares.
Dell has already replaced almost everything at least once under the warranty. On their request I wiped the disks and re-installed SBS2003 and recreated my user accounts and file shares from backup.
Any ideas?
  • Murray Mitchell Apr 14, 2009
    Thanks for the pointer, but by default the setting is 'always on' just checked to make sure, only thing that turns off is the monitor :(
  • Murray Mitchell Apr 15, 2009
    Thanks, managed to resolve it. thanks again
  • 48 Answers
Did you check to see if it is going into Hibernate mode in the power settings?
Posted on Apr 14, 2009
  • Tom Sutch Apr 15, 2009
    Are all fans working? It sounds like the processor may be overheating. Maybe try to run some diagnostics on the fans to make sure they're spinning fast enough...
Issue with time synchronizing(NTP) on layer 2 switch
I know this is probably not going to help you out but you did try going to Alcatel-Lucents web page and search through there or calling them at 800 995-2696? Good Luck! Sorry I couldn't be of some help
Mar 04, 2014 | Alcatel OmniSwitch 6850 (OS6850-48)
Server Randomly Reboots
First, go to Dell's website and update all the firmware and install the latest version of Dell Server Administrator. DSA has logs information not logged by Windows. Next, take it outside and blast the fans with compressed air, make sure all components and cables are properly seated in their slots/sockets, turn it on with the cover off and make sure all the fans are spinning. Many servers will increase the fan speed if they detect the cover is off so this is another possible cause to the problem.
Finally, Dell servers have lifetime support, this number should work: (800) 945-3355
BTW: A temporary workaround might be to use a network controlled outlet that you can remotely turn off and on. Your UPS might be able to turn outlets on and off or you could get a stand alone network controlled outlet. Some can actually ping the device and turn power off and on again if it stops replying to pings. (E.g. IP Power EV-9255 IP http://www.newegg.com/Product/Product.aspx?Item=9SIA1470N64280)
Mar 04, 2013 | Dell PowerEdge T300 Server
IBM server x3400 not starting
This is a Planner issue (Mother Board) . Open side cover and investigate capacitor status . Probably some capacitors are bulged . Check it and replace if necessary .
Good Luck
May 16, 2012 | IBM x3400 Server
My Rimage 2000i will not begin production of cd burn/print. Says there are no production servers active on cluster
Hello B13Designs,
If you receive a "No Production Server Active" message when using QuickDisc, make sure that the Production Server status is set to Active, Processing orders in Rimage System Manager. Once the Production Server is set to this status, jobs can be processed.
1. Open Rimage System Manager.
2. Select Production Server. Production Server status information displays in the right panel, next to the Production Servericon.
3. If Production Server is paused or stopped, press the play button. Production Server starts.
If this does not fix your problem, feel free to give our support line a call @ 1-800-553-8312 (Option 2).
Thanks!
Nov 18, 2010 | Rimage 2000i (530101320) DVD±R Burner
During bootup, the screen shows: 1. server raid-7k on board power-on self test takes up to 60 secones. after 60 seconds, displyed another line shows: status - not responding properly - error-code 2807
It means that your raid is not seeing its drives. Usually after a power failure.
Rebooting the server will fix it in the short term.
To fix it long term you need to update the servers firmware.
Aug 25, 2010 | Computers & Internet
HP DL380, drive 1 and 2 lights are not on, but 3 is. Can I swap new drives in those spots and it write automaticaly. Or is there and easy fix, I checked cables and connections, reset hardrives and powered...
Boot from HP Diagnostic Media (SmartStart CD)and check the status of Array.....or harddrives...
If showing any failed status or not supported..
Replace drives to check if new drives show status...
It could be because of Drives not intialise for Array..
Boot to Array Configuration Utility...during bootup and go to Intialise disks....
Use them
Oct 05, 2009 | HP Compaq ProLiant DL380 G4 Server
LaserJet 1600 offline status
Is the print server being assigned a IP address in your network?
Mar 05, 2008 | Trendware TRENDnet TE100-P1U Print Server
Power light
Are you referring to to Power LED or the System Status Indicator cause what I can remember from that particular model Dell server thst system status indicator was blue! Use this page to help identify what exactly is showing up as orange(or amber)! http://support.dell.com/support/edocs/systems/pe2600/en/sm/beep.htm#1057698 If it is the system status you'll need to go over the other indicators to troubleshoot what exactly is causing the problem! regards, babb
May 03, 2007 | Dell PowerEdge 2600 Server
Computers & Internet Logo
134 people viewed this question
Alun Cox
