Question about Water Heaters
Need i manual for candy 505/17 oven.can any one help
  • 88 Answers
Gas oven, gas goes on and off in the oven
Its suppose too,To keep the oven at the same temp
Jan 01, 2014 | Water Heaters
Error message E6 F2
From investigation, I would open the control panel (make sure the power is turned off first!) Look for a ribbon cable that goes to the Touch Pad and Control pad module. It should be able to be removed from the control board. Pull out the ribbon cable, and put the ribbon cable back into the connector. Be careful with the cable as they can be broken easily. Once you have everything back together, turn the power back on and test the pad. If it still doesn't work, the control board may be bad.
Nov 05, 2013 | Whirlpool Gold Resource Saver GGE390LX 30"...
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
Can't light oven in Wedgewood caravan oven
Do you have manual for proper lighting procedure? Do top burners have good flame?
Feb 27, 2013 | Atwood Mobile Products Atwood Wedgewood...
Where do you download a manual for whirlpool thin slim
Whirlpool has the manual for the LTE5243DQ on the product site: http://www.whirlpool.com/-%5BLTE5243DQ%5D-1001396/LTE5243DQ/ . The direct link to the Use and Care manual is http://www.whirlpool.com/digitalassets/LTE5243DQ/Use%20and%20Care_EN.pdf . Note: you will need Adobe Reader or a similar program to read the manual.
If you need the installation guide, use the first link above and then click on the Manuals and Literature tab.
I hope this helps.
Dec 15, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Thermostat keeps cutting power off to elba excellance oven
I have a similar problem with an Indesit oven. There are two thermostats one controlling the oven temperature which i think you have replaced and another over-temperature stat to prevent the oven getting to hot should the temp stat fail to control the temperature. The over- temperature stat could be operating to quickly and this cuts power to the the digital display, oven light, temp light and circulating fan. I am going to replace this over-temp stat
Jan 18, 2010 | Lux Elba OV 5085 LUX
Electric oven not working on our elba excellance oven. Thermo has been replaced but oven worked for 1 day then went again. What is the problem please?
Elba Oven not heating? How to replace a Elba fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
You searched for Elba element How to Repair Home Appliances
Jul 06, 2009 | Lux Elba OV 5085 LUX
Maytag gas range
The hot surface igniter is probably bad. Remove the igniter wires and check for continuity.
Apr 06, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Hot water out of taps is not very hot.
What is hot? Above 122F causes scald within 30 seconds. Get a temperature reading at tap. Use a candy thermometer if need be. If you want 140F water then your gas valve needs replacing.
In most code areas it is now illegal to deliver tap water over 125F to a consumer faucet.
You may love 140F but you jeopardize kids and Seniors.
Mar 03, 2009 | Honeywell Water Heaters
Water Heaters Logo
90 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
