Question about Nextway NMP-100C MP3 Player
Nextway NMP-100c Player
Hi, i've got quite an annoying problem with the NMP-100c Both the built in 64mb and the extra 64mb card i have in it won't play the music. When i turn it on it simply says "No Code" At first this only happened to the built in memory, but now it's happened to the extra card. Have i pressed anything i shouldn't have? Can i by any chance make the music that i put in again? Thank you. /Murvl
Re: Nextway NMP-100c Player
Have you tried reformatting the memory? The command should be on the Erase menu.
Posted on Feb 10, 2008
0 characters
3 Points
Why won't my Sansa 250R won't recognize an sd card?
Your 4GB card is actually a microSDHC card. The e250 works with microSD cards, 2GB and smaller.
Mar 10, 2013 | SanDisk Sansa e250 MP3 Player
I got nmp200r 8 yrs ago. I lost the driver disc. I want to use it again now. I need the driver to load songs into the player. Can anyone help thanks stan
Go to the manufacture's website and see if you can download the driver from them. If not all you need to do is search for a driver download. I would just enter you make and model into google and say that you wanted it to look for drivers.
Sep 24, 2009 | Nextway NMP-210R MP3 Player
I have Nextway nmp 312a but i don,t have drivers for him.
i need a driver for nextway 312a . i want to give it my doughter. please help me soon greetings Stephan
May 10, 2009 | Nextway NMP-312A (128 MB) MP3 Player
I own the player on my 2004 HD Softail Deuce. I have a catalog of various sizes of sd cards from my original 64mb up to 2gb. The problem you are having could be that you have the music in WMI instaed of having converted it to the mp3 format with your windows player. Be sure to use the lowest quality when converting to the mp3 as you will not notice the difference in the playback. Also do not be surprised that you cannot get what you think on a 2 gig sd card. One of my 2 gig cards has the entire Led Zeppelin studio catalog including some various Robert Plant solo songs from his various albums. I buy my sd cards from Microcenter here in Ohio for around $7.00 each. The local wal-marts are making a killing with 512mb for around $15.00 each, so shop around for the cards you need.
Jan 06, 2009 | Harley Davidson Road Tech HA90 MP3 Player
Nextway NMP-100C (64 MB) MP3 Player
It looks like Nextway went out of business. So I found a driver at that looks like it will do the trick. It's free to join and you have to join to download. This driver is for 3 models - including your model 100C. Here's the link for you.
Nov 19, 2008 | Nextway NMP-100C MP3 Player
Drive program
I own the same MP3Player and have the driver CD.
Jul 22, 2008 | Nextway NMP-210R MP3 Player
Sansa e260
The e260 works with microSD cards. Your 4GB card is actually a microSDHC card and won't work in the Sansa.
With a microSD card, simply put music tracks into a folder called "MUSIC". When the card is installed, the Sansa will see the additional tracks.
Jul 14, 2008 | SanDisk Sansa e260 MP3 Player
Music isn't showing up on my computer so I can't delete or update! =S
Using msc mode, use my computer and right click on the drive corresponding to the mp3 player, and select format. That should clean up anything that's causing problems.
As far as the player refreshing every time it starts, this is NORMAL, and it WILL take extra time since you have an additional memory card to scan.
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
Memory card
Had the same problem with 64MB, but was able to use store music on 32MB and 256MB SD cards.
Oct 22, 2006 | Rio Chiba Street MP3 Player
Nextway NMP-100C MP3 Player Logo
57 people viewed this question
Top Nextway MP3 & Digital Media Players Experts
Are you a Nextway MP3 and Digital Media Player Expert? Answer questions, earn points and help others
