Question about Samsung Digimax S750 Digital Camera
Many horizontal lines appear on the picture
My samsung S750 worked perfectly more than 1 year. But now when i took a picture there are many horizontal lines (like ripples) on the taken picture. I tried to solve this by resetting the camera but failed to solve. Can any expert please advise me regarding this problem.
  • Anonymous May 06, 2009
    I have EXACTLY the same problem. I have the camera for about 1.5 years, and now i see the same strange horizontal lines on every picture. I tried resetting as well, with no help.
    I tried all picture modes, all resolutions and all manual adjustments. The only time i don't have the lines is when i use the "record video" function.
    It only happens with still pictures.
    President:
  • 1,223 Answers
CCD FAILURE!
Call Samsung for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
Posted on May 23, 2009
I have got the same problem, but I can't call samsung for free repairs, because the guarantee is expired. What can i do?
Posted on Aug 14, 2010
4 Suggested Answers
SOURCE: My camera seems to short out and there are horizontal lines in the pictures.
get new batteries, if recharging your current batteries does not work (to stop it shorting out).
reduce your shutter exposure, by changing to Manual Mode (M), selecting +/-, and then the left button (flash) around the Menu OK button. Mine works fine at 1s shutter speed, but was showing horizontal lines before that ...
Posted on Jul 09, 2009
  • 11967 Answers
SOURCE: pics turn white with lines when taken outside in day light
Check to see if your ISO is set to a high number like 800 or 1600. If so, set it lower or on auto ISO. Your white balance should probably be on auto white balance. Go into the setup menu and see if your camera has a setting for "reset". This could take your camera back to factory defaults.
Posted on Aug 29, 2009
lock123
  • 6831 Answers
SOURCE: my camera went from working perfectly one minute
Hello
OK, this sound to me like you have a blown CCD. Unfortunately, you will not be able to repair this yourself, but, you can take it to your nearest camera repair shop.
They will be able to inform you to exactly what the problem is, as well as the repair cost.
Kind regards
Andrea
Posted on Aug 29, 2010
Testimonial: "Many thanks! I loved this camera, it would be nice to get it working again as it's idiot proof!!"
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
3 horizontal lines on Samsung LN46A650 upon start up. Causes the Tivo menus and on screen graphics to refract. Goes away within a 1/2 hour but returns when powered down and restarted.
I had the power board capacitors on my Samsung 46LNA650 checked, and the out-of spec/leaking ones (13 in all) replaced. The horizontal lines disappeared; but, the left side of the panel was dark for about 20 minutes (until warmed-up). I then found this forum/link that solved the problem! This simple fix was probably all that was ever needed - IT WORKS!!!!!!
http://forums.cnet.com/7723-13973_102-391250.html
My Samsung now has a perfect picture again.
Nov 16, 2010 | Samsung LN46A650 46 in. LCD HDTV
I have a Sony Cybershot DSC-S750. I recently dropped it in some water, so I came home, took the battery out and dried the camera for 2 1/2 days. Now when I take pictures there are white lines running...
First of all, you're lucky it turned on at all. Usually, a camera must be buried in a bowl of dry rice for a week before it is completely dry. Even then, only if it was dropped in distilled water would it work properly. Ordinary water will leave deposits that will change the way the camera behaves. Salt water is even worse...it will continue to corrode the electronics long after the incident.
Nov 11, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
Every time i took a picture theres a line appear
When I take a photo from Canon A470 the horizontal lines are appear in all over the picture pl. give me the solution
Dec 28, 2009 | Canon PowerShot A470 Digital Camera
Why does my cyber shot dsc-s750 has lines when i took pictures.?
Please follow the following steps or lookup page 14 and 16 of your user guide.
Jul 07, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Horizontal pixel line
I have seen this B4 here is a link that may help. http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Mar 31, 2007 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Samsung Digimax S750 Digital Camera Logo
917 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
