Question about Tomtom GO 720 GPS
Replacement TomTom Mount
It doesn't take long before the supplied suction cup with the TomTom GO 720 becomes less adherent to the windscreen resulting in the device constantly falling off. Is there a replacement suction cup available or a more efficient and cost effective replacement mount available.
5 Suggested Answers
E61N
  • 515 Answers
SOURCE: Moving a Tomtom GPs
Clean surfaces... press rather firmly...
Posted on Aug 05, 2008
SOURCE: Cant make Tomtom mount stick to anything
you need to pull the two ears on the sides of the suction cup away from the windshield before you tighten it down. its really easy once you figure it out. hope this helps
Posted on Feb 26, 2009
  • 32 Answers
SOURCE: Suction cup mount keeps falling off windshield
The suction cups ****, don't they? ;-)
The problem is that temperature variations (bright sun vs. cloudy day) causes pressure changes inside the vacuum seal, and it eventually fails.
You can try spraying the cup with water before attaching it...the water helps the cup keep a better seal. Vaseline works even better.
Ultimately, I ended up buying a universal mount that fits right onto one the dash ventilation louvers...no problems since.
Posted on May 16, 2010
  • 1514 Answers
SOURCE: how do you attach the grip to the suction cup
On the end of the suction cup there's a ball shape. On the grip there's a small plastic cylindrical piece. Push the ball into the cylindrical part. It's a tight fit so you'll have to push hard.
Posted on Sep 25, 2010
My suction cup for my in car camera will not stick to windscreen keeps falling off how to make it suction properly and not fall off
That is pretty typical.
If you want to mount it to the window, then make sure the glass surface is completely clean. A generous amount of saliva on the suction cup will keep it up on the glass for a while.
You are better off using the adhesive backed suction cup disks and mount it to your dashboard.
Jan 11, 2017 | GPS
Mounting of gps can't mount on windsheild.
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Jan 04, 2011 | Tomtom ONE XL GPS
WIll not adhere to the windshield... suction cup does not hold GPS
Dec 31, 2010 | Tomtom GPS
How exactly do i fix the suction back onto the windscreen please? I have just bought a tomtom and don't understand the drawings!
Dec 31, 2010 | Tomtom ONE GPS Receiver
I got the standard mount with TomTom GO 730 and it just does not seem to work. The first time I had placed it on my windshield which I was later told was the wrong place to put it (the included maual in...
This is a fairly common issue especially with aftermarket tinted car windscreen 'film'.
You can try prolong the suction by wetting the suction cup with water of very slightly soapy water before applying it to your 'clean' windscreen area.
As for the dashboard, for some models, TomTom provide a plastic circle to which the suction cup attach to. The plastic circle is first 'permanently' attached to your dashboard with double-sided adhesive tapes.
Hope it helps: let me know how you go.
Jan 08, 2010 | Tomtom GO 730 Car GPS Receiver
We installed the car cradle to the windshield but receiver won't adhere to the disk. Please tell us what we did wrong. Thanks, Pat skillman
i think you mean the mount wont adhere to the disk..normally the disk is not used to mount the gps to the windshield, is more for the dash area or another spot where the suction cup wont adhere. the are rare occasions where the disk is needed for the windshield though, but its rare. try ataching it to the windshield without the disk. lift lever at suction cup, press the mount firmly against the windshield, then press the locking lever down to secure the mount. the picture below is the wount in the unlocked position.
form Magellan
This adhesive disk provides an alternative to mounting your Magellan GPS to the windshield of your vehicle. The disk adheres firmly to your dashboard or virtually any surface. Then attach the suction cup of your windshield mount to the disk.
Aug 14, 2009 | Magellan Roadmate 1200 Car GPS Receiver
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
Feb 23, 2009 | Tomtom ONE GPS Receiver
New GPS for Car - mounting directions not clear
you can mount to the dash there should be a black disk that came with your package it is round and will have a sticky pad on the back of it with a piece of shiny paper on it first find there you want to mount it and clean the surface well i would suggest rubbing alchol to clean the surface then remove the shiny paper from the disk and with the sticky pad don attach to the spot you cleaned from there you just attach the mounting suction cup to it
Dec 28, 2008 | Tomtom GPS
Windscreen holder for tomtom
I didn't like the suction mount because it doesn't always hold very well and it was a little distracting. I found a vent mount at mountguys.com for less than $15 delivered that I am very happy with.
Jan 27, 2008 | Tomtom ONE GPS Receiver
Tomtom GO 720 GPS Logo
868 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
