Question about Epson LQ-2180 Dot Matrix Printer
Unable to do a reverse line feed
I am developing a retail software, and for printing invoices we are using preprinted paper. So after printing the invoice i need to advance the paper so that they can tear it off. So before printing next bill ineed to reverse the paper few lines. And my problem is here, i am using the print document to create the invoice. I am doing this visual foxpro to develop this.How can i solve this problem?
Describe your Epson LQ-2180 Dot Matrix Printer Problem
Posted on Jun 18, 2009
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Hi, One of our client using epson lq-300+II dot matrix printer to print their invoices in custom defined paper (using crystal report). It was working fine when they were using windows xp. Now they...
Hello, Please, if you can change back to the former operating, is either the printer type is not compactable with the new windows(Windows7). But first you have to check the net to see if you can try upgrading the software of the printer. Please if you've done this let me know what happened next.
Mar 26, 2011 | Epson LQ 300+ Matrix Printer
How to print preprinted labels
Have to callibrate the printer.
With printer ready
press Pause once.
press Pause for 3 seconds until
- The labels are fed (let 3 labels go through)
the Choose detection preprinted lmabels in the driver
Or
a message Transmissive is displayed.
Release he pause button.
Press on the pause button to feed 2 or 3 labels
Then select transmissive preprinted in the driver.
Else
Restart to change from transmissive to reflective if you use black mark.
Press pause to feed 2 labels
Choose relective preprinted or reflective manual in the driver
May 19, 2010 | Toshiba TEC B-472 Thermal Label Printer
Dotmatricx printing
Each machine has it own printing language (HPCL, HPGL, PostScript, etc.) You must first find out what command language it responds to.
Hope it helps.
Aug 28, 2009 | Epson LX-300 Matrix Printer
Cant print continuosly in epson lq300+
Sounds as if the format is wrong. You must set the paper format in the PC wordprocessor or invoicing software to the same size as the actual paper size of the invoice.
Jul 08, 2009 | Epson LQ 300+ Matrix Printer
We are using 20 lb plain paper and everything works well. We swith to a 20lb preprinted paper and it feeds several sheets at one time. Can you explain?
There is a coating on pre printed paper, new sep rolls should help, rember that the coating can be bad for your printer.-Carl
Jul 07, 2009 | IBM Infoprint 1422 Laser Printer
How to do a reverse form feed in Visual Basic 6
Two things to consider:
1) The printer itself must be designed to handle reverse form feeds. I am not sure how many these days are.
2) If you're printer can handle reverse form feeds then it should be a simple matter to send the appropriate ascii code to the printer to initiate it. Much the same as if you wanted to have the printer do a line feed.
Good luck and thanks for using FixYa.
Mar 18, 2009 | Microsoft Visual Basic 6.0 for PC
Sending Reverse Line feed to Epson LX-300+II USB printer
Hi Shery,
I went through the manual of LX300 printer series.I believe that if u read that manual, you can Fix the problem as it has all instruction about the Reverse feed and pull tractor mechanism.
Download Manual
http://ftp.epson.com/pdf/lx300p/lx300ppg.pdf.Any issue contact me.
Thank you
Riz (zyrixdown3@gmail.com)
Feb 11, 2008 | Office Equipment & Supplies
Epson LQ-2180 Dot Matrix Printer Logo
521 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
