The problem is caused due to user profile corruption . Generally caused by a worm called Sasser. Following are the steps to resolve the problem.If the following steps donnot work then the only solution would be an operating system reinstall .
To resolve this problem, follow these steps:
Insert the Windows XP disk in the CD drive or DVD drive on the computer. Press and hold down the SHIFT key as you insert the disk to prevent the Windows XP installation from automatically starting.
Click Start, click Run, type the following command, and then click OK:
expand CD drive:\i386\ntdsapi.dl_ %SystemRoot%\windows\system32\ntdsapi.dllNotes
Make sure that there is a character space between "ntdsapi.dl_" and "%SystemRoot%."
CD drive represents the drive letter of the CD drive or DVD drive that contains the Windows XP disk. For example, if the letter of the CD drive or DVD drive is E, type the following, and then click OK:
expand E:\i386\ntdsapi.dl_ %SystemRoot%\windows\system32\ntdsapi.dll
Click Start, click Run, type cmd, and then click OK.
At the command prompt, type the following command, and then press ENTER:
xcopy c:\windows\servicepackfiles\i386\ntdsapi.dll c:\windows\system32
When I turn on the power the Compaq Screen flashs and then I get Press to resume to setup But...
(More)
When I turn on the power the Compaq Screen flashs and then I get Press to resume to setup But nothing happens when I do either. I tried to use the recovery disk. You can hear the fan, you can hear the CD drive but nothing on the screen? Can you help?
instale windows 7,en mi compac empresario,pero no tengo el controlador de video,me puedes ayudar,soy...
(More)
instale windows 7,en mi compac empresario,pero no tengo el controlador de video,me puedes ayudar,soy zanche1940@hotmail.com dede venezuela,saludos
How do I stop or adjust the scroll feature on my touchpad ? I tried messing with the mouse in...
(More)
How do I stop or adjust the scroll feature on my touchpad ? I tried messing with the mouse in control panel and it didn't help.
Yes hello, my name is Ben and im having a problem with my laptop, its a v2000 a friend gave me, i am...
(More)
Yes hello, my name is Ben and im having a problem with my laptop, its a v2000 a friend gave me, i am wanting to fix it up and give it to my parents for Christmas, I can also understand everything u say to me about a computer, so u can reply computer talk. Okay, now i have been having a problem i JUST CANT FIX. its starting to make me mad, it is doing the following: When i turn it on the compaq screen starts up, but i cant press: Esc for boot menu F10 for setup or F12 for LAN boot. Sometimes if i turn it on and press Any one of those keys many times it will go to a screen that says press F1 to continue or F10 for setup, but still none of these keys do anything. It beeps twice on this screen, its a short non-loud beep. Now last, i have opened the laptop as i thought maybe the Cmos needed to be reset, so i took the battery out and back in. while i was in there i decided to look at the whole computer, so i looked at the processor, i had a little bit of what it looked like burned stuff on it. there was some burn marks on the metal looking thing and around it on the green part on the chip. what does this sound like to you. i think it is either 1 of 2 things: the processor is dead or the BIOS was corrupted and i cant flash it because i cant access the boot menu!!!!
