Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
No Power Hey everyone, I have power at the wall, but no power at the dishwasher. the garbage disposal is on the same circuit and it is working. I pulled the fuse behind the control panel after cussing several times seeing that I broke the ribbon cable for the buttons in the process. I do not know how to visually tell if the fuse is blown. Thanks,
    Problem Solver:
  • 5 Answers
If it is a Kitchenaid KUDS25 series, there is a thermal fuse located on the upper portion of the electronic control panel. You will need a continuity meter to test it with the power OFF. In addition, check that the door latch switch closes properly and has conductivity across the two spades with the door closed. However, it sounds like you have bigger problems now with the broken ribbon cable...
Posted on Jan 25, 2008
Lights will not turn on
I experienced the same problem. One day the lights on the unit weren't on. The wall outlet that the dishwasher uses had power because the Garbage Disposal that also uses the same outlet had power. Turns out the power supply cord also tied to the water supply hose and had over the months (due to the constant slapping or dancing of the water hose whenever the electrically controlled water valve was opened or closed), had caused the female receptor prong inside the wall outlet to loose continuity with the male prong of the dishwasher power cord. It might have been a defective wall plug all along but the wall outlet worked for months before the problem arose. Anyway, after replacing the wall outlet the dishwasher again has lights and works fine.
Mar 06, 2015 | KitchenAid Dishwashers
How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
Dishwasher LD-1420T1 tripping power in the house?
Okay, this could be tricky because depending on who installed it, they might have wired into it. Check your garbage disposal and if you have anything else plugged in nearby, check that wiring too. Some installers have a nasty issue when it comes to hard wiring. They don't like doing it. So instead of hard-wiring your garbage disposal, they'll cut it in to your dishwasher. If your garbage disposal or anything else is wired to your dishwasher the load on the washer and the current the washer is using is too high. That's going to trip your breakers. You should probably contact an electrician and have them check the breaker box to make sure it's wired correctly. You may need to upgrade the breaker or have the dishwasher circuit upgraded. If it's an old house, it could be anything but first, check to see that nothing is wired into your dishwasher. You can tell if you have a few switches in the same outlet and turn them off. If your garbage disposal won't work and the DW won't either, then you have a wiring issue. That's the easiest way to start.
Apr 06, 2014 | LG LD-1420T1 Dishwasher
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
Dishwasher not working after power outage
Occasionally there is an isolated GFCI circuit for the dishwasher. If you can validated with a voltage meter that the unit is actually getting power.
I used to always install an isolated GFCI circuit for each: microwave, dishwasher, refrigerator, and garbage disposal.
So that is what i would check first
Mar 14, 2010 | GE Dishwashers
DU943PWKSO DISHWASHER STOPPED WORKING, ELECTRICAL CURRENT TO PANEL BUT DOES NOT START NOR DOES ANYTHING TURN ON. LAST YEAR HAD THE SAME PROBLEM TECH TOOK FRONT APPART AND THE DISHWASHER STARTED WORKING. I...
Check you electrical power box that feeds to the house. If this dishwasher is hooked up under a sink counter and there is a garbage disposal in the sink area the dishwasher should be hooked up to the same circuit that the dishwasher is hooked to. If the garbage disposal works then the circuit is good your problem is either in the connection from the plug to the dishwasher or in the timer section of the unit. Either way the unit wont operate. Check power into the unit then check power at the hookup from the dishwasher to the plug itself if all is good then timer has gone bad
Good luck hope this helped you some
Dave
Jan 28, 2010 | Whirlpool DU943PWK - Multiple Color...
No power to my dishwasher
A diswasher is normally plugged into a non-switched outlet under the sink. Make certain the power cord hasn't been knocked out ot the outlet.
Most homes today come pre-wired for a garbage disposal, as well. Normally there will be one duplex jack under the sink, one jack "always on", the other controlled by a wall switch above the counter. If you don't have a garbage disposal, make certain the dishwasher is plugged into the "always on" jack.
Mar 09, 2009 | Frigidaire 24 in. PLD2850 Built-in...
BADGER GARBAGE DISPOSAL NO POWER
Have you checked the circuit breaker on the disposal itself? In the bottom there's a little button that resets the circuit breaker. press it in and see if that works. If the disposal is still jammed you should hear a hum.
Dec 28, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Apr 07, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher doesn't run
If you turn on the dishwasher and nothing happens: 1) Be sure the power is on, the door is latched, and the control is turned on. Also make sure the appliance cord is plugged into the electrical receptacle under the sink (some are hardwired and don't come unplugged). If it can be unplugged, make sure the electrical receptacle is working (plug in a working appliance or a circuit tester). 2) If that doesn't solve the problem, the door switch, the timer, or the selector switch may be defective. To solve the problem, you may be able to adjust the door latch's strike slightly, using a screwdriver (turn off the power to the dishwasher at the electrical panel when working on it). 3) If that doesn't work, call an appliance repairperson.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
158 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
