Question about Panasonic NN-H275 Microwave Oven
Panasonic Inverter Microwave stopped working - no power
I was using the microwave this morning (2 years old only) and use the timer on it when I'm cooking things in the oven. I was busy and must have accidentally set it on 45 mins on High, when I meant it to be the timer. It was on and I didn't notice it with nothing inside it and I noticed a funny smell (probably a burnt out fuse) and it overheated and stopped working.
Is it worth repairing it and is it simply a matter of replacing the fuse?
Thanks
June
SOURCE: PANASONIC INVERTER MICROWAVE, 1300 WATTS
  1. Same exact problem
  2. I've noted 3 different ones with the same problem
  3. Panasonic has produced a lemon, north fixing
Posted on Apr 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave runs for 3 seconds and shuts off
This is an inverter-driven model, and this is one way the inverter fails. Often it will tick, too, but the cooling fan may be too loud to hear ticking. If you haven't had smoke, then it may not yet catastrophic. I would bet that a thorough resoldering would take care of it. A good technician can troubleshoot and repair this, as needed, but often they will just replace the inverter. Sometimes that's actually cheaper. Troubleshooting an inverter is way too much for someone without good solid technical experience. I would call a shop and ask for an estimate to replace the inverter. Good luck.
Posted on Oct 14, 2006
joust
  • 7 Answers
SOURCE: Panasonic NNC980 - stops working after 3 seconds
you have a bad inverter board.
Posted on Feb 16, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Genius Sensor 1300W
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Aug 30, 2009
  • 24 Answers
SOURCE: No power. I changed fuse but microwave blows it immediately.
Be very careful! Standard microwaves have 2100volt capacitors and commercial ones 4000 volt capacitors.
*Decharge your capacitor(s) before doing diagnostics*.
You are now testing the high voltage side (as it works on convection). The main components are a transformer, a capacitor, a diode and a magnetron (havent seen a triac in a panasonic residential). If you have a proper meter that can test uf, decharge the capacitor, then test the capacitor, if it reads 0, you need a new capacitor (10$ used typically, 14$ new from ebay). To test the magnetron, decharge the capacitor first, remove the spade connections, test each leg to the frame of the microwave... if it shows measurable resistance, the magnetron is bad. The transformer is not something you test as I personally dont have a 4000 volt meter. If the diode, the magnetron and capacitor are okay, then the transformer is bad. To eliminate any other function, disconnect the low voltage to the transformer run a micropower cycle and check the fuse.
Hope that helps. My first instinct is the capacitor.
Posted on Dec 19, 2009
My panasonic microwave stops working after 6
If it stops after 7 seconds, it has a problem with the inverter.
Aug 09, 2009 | Panasonic Microwave Ovens
The carbon monoxide detector beeps when I run the microwave.
uplug the micro wave for the same amout of time the dector go off and see what happen if it goes off check the battery and replace them and do the same as above test to see if dector is not working properly
Jul 01, 2009 | Panasonic NN-T990SA Microwave Oven
3 year old panasonic otr microwave stopped working
Sorry but if the fuse is good your out of luck. but ck. the fuse first. best reguards DFD
Apr 12, 2009 | Panasonic Microwave Ovens
Panasonic Inverter Microwave, NN-H665BF, Smoking Issue
The magnatron is covered by warranty for 5 years and I just spoke with an authorized Panasonic repair center who said the inverter is covered on this unit depending on the manufacture date, like april 04 to october 05 approximately.
Jan 21, 2009 | Panasonic NN-P294SF Microwave Oven
Are microwave safe egg poachers doing damage to microwave?
you are not supposed to have any metal in the microwaves for cooking something , as why the other two quit , that is probably why they quit so soon
there is some more exspensive microwaves that can work even when metal is used inside( but these are special types of microwves)
Nov 10, 2008 | Danby DMW1153 Microwave Oven
Panasonic Microwave Problem
Even though these are different symptoms, the same part may be causing both.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Sep 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
NN-T990SA Panasonic Microwave Stopped Heating
This model uses an inverter to produce high voltage instead of a convential transformer system. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. Most offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number.
Dec 21, 2006 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-H275 Microwave Oven Logo
735 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
