Question about Braun Aromaster KF 400 Coffee Maker
Help i pushed the rubber in the water container (the small black rubber that sticks out from the little tiny hole) and now when i put the machine on the coffee doesnt get despensed into the coffee jar and there is a loud noise coming from the machine.
  • Anonymous Mar 14, 2014
    Hi i was washing my water container and the little rubber came off dont know how to put it back
  • 127 Answers
Maybe you have blocked the hole with the rubber grommet.
disassemble and reinstall it properly
Posted on Jan 04, 2010
Brand new just tookout of container and wont stick to windshield
Sometimes the rubber plunger plastic/rubber new is not worn in yet, take rubber plunger part off, soak in warm water for a few minutes, then bend it in just a few times, put a dab og saliva on it stick it on and push lever back firm, twist suction cup some before putting lever down to secure it. If this helped, please rate with 4 thumbs , to help me and others. Thanks mike from fixya
Jun 16, 2011 | GPS
Error...EO4 showed up, got the washer unlocked and now it wont drain.
The machine is a bit different than most washers, so here is help when you get "error 04"...Your pump is plugged. There is a round 'door' on the lower front of the washer. At the 5-O'clock position in the door there is a small hole. Put a small screwdriver blade in the hole, push in (just a little), and you can rotate the door clockwise. When the hole is in the 6-O'clock position, the door will come out and you can get to the problem.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. (We used a pile of towels to catch this). The Black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog.
Mar 20, 2011 | Bosch Washing Machines
WATER APPEARING UNDER CRISPER DRAWERS
If the interior hole is clear, you may also want to check where that short pipe dispenses the water into the defrost tray on the rear of the fridge.
Remove the back lower panel carefully and feel on the inside of the opening, just above the center. You should be able to feel the end of that pipe, although you won't be able to see it easily. Feel to see if there is an obstruction there (mine had a tiny ball of pet hair clogging the end of the pipe).
Also, there should be a little rubber 'gasket' with 'fingers' that extend over the opening of that pipe. It was suggested by FP tech to snip a couple of those fingers to allow water to move more easily.
Mar 20, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
My boschMaxx washing machine is not spinning and laundry is quite wet
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate.
Or improper detergent is being used, ( must use "HE"/lo-suds detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely.
Pl rate me 'very helpful' for the free help, thnks!
Feb 18, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My bosch 1200 classixx WAE24164GB will not spin or drain
Oct 26, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Calssixx 1000 Express Washin Machine
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Pl rate me 'very helpful' for the free help, thanks!
Sep 08, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Burned out bulb.
Generally on an Elna there's a little hole on the very top of the sewing machine directly above the bulb.
Pushing a long, skinny stick (like a screwdriver,) down into this hole will push the lightbulb and socket assembly down to where you can actually access the bulb without having to try to skvoosh your fingers into the tiny space.
-R
Aug 28, 2008 | Elna Quilter's Dream 6003Q
Rugs won't dry
Jun 22, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Just stopped working
I am sorry I might not be able to explain in English very well, but I hope it will help somebody.
In my case, the pulp container was a problem.
when you take out the container, do you see the little(very very small )hole that if you push with something like toothpic it makes sound like "click, click"? I guess when we put the pulp container back, the container is supposed to push the safety button ( bottom area), but I think the part of the container that push the button was broken, and it didn't start,so I just put something small inside the hole before I put the container back to the juicer, so it covers the missing part.
Their customer service doesn't help at all, I waited 1h to talk to somebody, and he couldn't help me. so please check that part.
Sep 04, 2007 | Jack Lalanne Power Juicer (Stainless...
Braun Aromaster KF 400 Coffee Maker Logo
82 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
