Question about Canon PIXMA MX300 All-in-One Printer
USB device not recognised malfunctioning
I have tried everything. Reinstalled drivers three times, disabled virus program, checked connections, restarted computer, all the solutions suggested in the manual. Nothing works on my Windows Vista Home Baci program.
  • johannes_con Apr 12, 2009
    The printer worked perfectly with my earlier Windows XP and the same printer cable. I have tried the printer cable in two USB ports without success.
    Problem Solver:
  • 7 Answers
Try to plug the printer usb cable to all the usb ports you have at your pc. if still not working, change the usb cable.
Posted on Apr 12, 2009
When I turn my printer on I get the USB device not recognised message - says the device has malfunctioned and no matter what troubleshooting tips/steps I follow nothing seems to change it. Everything seems...
It is possible that there are errors in the driver software and so a reinstallation is needed. So remove printer and then open programs to uninstall the printer software. Now shut down and then restart download the drivers and install , connect the printer ONLY when prompted and then check .
This might clear the issue , if not there are problems in the mother board.
Sep 03, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Oct 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi i have an everio gz-mg 135 and when i connect it to my pc to back up files the message "usb device not recognised. One of the usb devices attached has malfunctioned. Windows does not recognise...
- Make sure you have been installed JVC driver on your PC - If your PC has multi ports USB, just try other ports to make connection - check your firewire, it may be malfunctioned . Try other USB cables
Jan 16, 2011 | JVC Everio GZ-MG130 Camcorder
I have installed the software three times. The
THe device is not responding to the driver, it seems to be hardware problem wit hthe camera as it is recognised.
Apr 11, 2010 | Samsung Pleomax PWC 3800 Webcam
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Presario A900 A976TU USB Port Issues
It may be that you need to update your drivers
Start here
Microsoft's built in drivers may not be making best use of your hardware and causing the problem you describe.
The driver may be for the motherboard and not usb.
Either way it provided you with the opportunity to update other drivers too
Aug 24, 2009 | Compaq Computers & Internet
FujiFinpix A607. Getting device not recognised when USBconnecting
make sure the software is unstalled via control panel, ad and remove programs, make sure there no mention of finepix now load the software first, then plus in the camera check the usb cable as well
Jun 14, 2009 | Fuji FinePix A607 Digital Camera
My usb flash drive is working but my computer not recognising
Check for viruses your USB .If it is allright.
Check your USB Stroge drivers .Are they installed.?
Dec 24, 2008 | Transcend (589307) Media
HP desktop- had virus- reset computer, now no sound
Hi , to install sound driver.
open the control panel ,install sound driver and also check device driver view if the sound connect to computer.
Feb 08, 2008 | Computers & Internet
Software driver problem
Do any other devices connect successfully to that same USB port?
If no, try another USB port.
If yes, when you reinstalled your software, did you uninstall first? If not, see if you can. Once uninstalled, verify that the device is removed via Device Manager.
Once removed, if on XP or Vista, try to connect using the built in system drivers.
If this does not work, try reinstalling your drivers, but be sure to check for system prompts when you connect. If you do not respond to those prompts, the device will not mount.
Let me know how it turns out.
DigiChick
Nov 05, 2007 | Fuji FinePix A340 Digital Camera
Canon PIXMA MX300 All-in-One Printer Logo
141 people viewed this question
old marine
old marine
