Question about Compaq Armada 3500 Notebook
Armada 3500 power supply pin assignment
I am trying to hook up another 15V 2A AC adaptor to this laptop.
However the power supply socket has a flat 3 pin socket , wondering which pin is what ?
The power supplies / ac adapters for my AW-871 speakers were both lost in a recent move. The speakers show input of 15v center + but no power spec. Do you have a suggestion for replacements? Thanks for...
Higher voltage then required is not so recommended, internal circuit may over voltage driven. some power amp max limit may fall within 18V only. See this link If your speaker power less then 30w you can choose 15V 2A will do or else select higher spec.
Jul 23, 2011 | Acoustic Research 900MHz Wireless Stereo...
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
Compaq armada 7400 does not turn on
Please turn off the Computer and disconnect the AC Adaptor then remove the Battery. Next, try cleaning the metal contacts on the Battery and reseating the RAM modules.Then, connect only AC Adaptor to the Computer and try to turn it ON without the Battery. If the Computer doesn't turn ON then disconnect the AC Adaptor and insert the Battery then try turning ON the Computer. If the issue persists even after performing all the above steps then service will be required.
Jun 23, 2009 | Compaq Armada 7400 Notebook
Keeps powering on and off.
Keep in mind since you cleaned it out, only have the AC adaptor hooked up to rule the battery out. If the laptop stays on with only the ac adaptor hooked up and doesn't shut off then you know that the battery is faulty. If it still shuts off even with just the ac adaptor hooked up then it could be the ac adaptor.
Also check one more thing, with only the ac adaptor hooked up, wiggle the cord where it plugs into the laptop and see if the laptop shuts off, if it does then the dc jack on the motherboard is loose and needs to be resoldered back into place so it stays put.
May 13, 2009 | Dell Computers & Internet
Need to replace
Here is one on ebay:
http://cgi.ebay.com/AC-Power-Supply-Adapter-for-LG-SAD7015SE-15V-5A-4-Pin_W0QQitemZ260399450508QQihZ016QQcategoryZ101265QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Apr 25, 2009 | Zenith L20V36 20.1 in. EDTV-Ready LCD...
Compaq armada m700 wont power up all the way
Sounds like you may have a problem with the internal power supply box? I am not sure but that may be at least something for you to have checked out. If the fan is not spinning this is usually a sign this may be what the problem is. GOOD LUCK!
May 13, 2008 | Compaq Armada M700 Notebook
3350 power connector specs
The Pin Assignment is as follows:
Pin 1,4: +5V
Pin 2,3: not connected
Shield: Ground
The AC Adaptor is specified as 5V , 4Ampere. Actually the unit draws around 2-3 Amperes.
/ 3 1 \o
\ 4 2 /
This "Image" shows the pins, when you look onto the jack at the back side of the terminal, with the terminal standing upright. The label = 5V is located left of the jack
Jan 20, 2008 | WYSE Winterm 3350SE Network Terminal
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Compaq Armada 7400 AC Adaptor Pins
Below is the URL for compaq's Service Manual for that model. This shows you the details of every single part & how to disassemble and reassemble every screw. Surely it has to be in this document, somewhere. --> ftp://ftp.compaq.com/pub/supportinformation/forum/portables/7400msg.pdf
Aug 04, 2007 | Compaq Armada 7400 Notebook
Compaq Armada 3500 Notebook Logo
132 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
