Question about GE JVM1850 1000 Watts Microwave Oven
Surface Lights won't go off
I replaced the burt out light bulbs that shine on the cooktop surface and they now won't go off. Do you have a suggestion. FYI the model is in fact the JVM 1870WF06. Thanks
  • GE Master
  • 9,150 Answers
This is a problem with the control panel assembly, which we repair nationwide for $39.95. Full details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
I have a GE micro ange hood Model# HVM1540DM1BB, bulbs blew,change them out, now the lights will not shut off. I have powered it down over night, pluged it back in next morning same thing. Any ideas
There is a possibility that the light relay is stuck on. Sometimes a sharp tap on the relay will fix it. If not the control board will need replacing.
Sep 26, 2014 | GE Microwave Ovens
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Can I replace the surface light switch on a SCA1000HBB microwave or do I have to call for service?
From the ever-handy owner's manual:
1. To replace the cooktop light/
night light, first disconnect the
power at the main fuse or circuit
breaker panel.
2. Remove the screw from the
side of the light compartment
cover and lower the cover until
it stops.
3. Be sure the bulb to be replaced is
cool before removing. Gently pull
the bulb from the receptacle.
Replace with a 12 volt, 20-watt halogen
bulb. Order WB36X10176 from your
GE supplier.
4. Raise the light cover and replace
the screw. Connect electrical
power to the oven.
Jan 14, 2010 | GE Microwave Ovens
NEED TO KNOW SIZE OF SURFACE LIGHT BULBS.
went to the store a got a new one
Jan 15, 2009 | Microwave Ovens
JVM1460 surface light problem
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Surface Lights Don't Work
We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
82 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
