Question about Acer Aspire 3613WLMi Notebook
Bluetooth not working
Acer 3613 built-in bluetooth not working
I have an Acer Aspire 7741z. I don't think it has built in bluetooth. I downloaded the BT software from Acer but I don't know what to do now. It still doesn't acknowledge any BT devices.
No, this model does not have Bluetooth capability built in. There are USB powered Bluetooth adapters on the market however. As a matter of fact, search Wal-Mart's website for "Bluetooth adapters" and you should get a wide selection of choices.
Feb 17, 2015 | Acer Aspire Computers & Internet
My bluetooth Device is not shown or discoverable.
Reinstall the driver. It might think it's installed correctly. If the suite is an application outside of the driver, then reinstall the suite also.
May 02, 2012 | Acer Computers & Internet
My built-in bluetooth device is not being detected after I upgraded from windows vista to windows 7. I tried installing the bluetooth driver from the Acer website, but it didn't work. I tried using an...
Just looked on ACER website, they offer Win 7 support for the 11.6" but not the 15.4". If yours isnt the smaller model you could still try the driver get it here http://www.acer.com.au/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3112&sp=page15e&ctx2.c2att1=92&miu10ekcond13.attN2B2F2EEF=3112&CountryISOCtxParam=AU&ctx1.att21k=1&CRC=3559666452
If no luck download software program Driver max from www.drivermax.com it will scan your laptop for all available drivers and unknown hardware..........good luck from Scott
Mar 18, 2010 | Acer Aspire 1410-8414 Netbook
Bluetooth problem on my acer extensa 4220
Most Acer product does not have in-built bluetooth. what they have is the application supporting bluetooth device. The best you can do is to get any external bluetooth device and install it driver as well on your Acer laptop, this will surely work.
Sep 20, 2009 | Acer 4220-2346 Notebook
Bluetooth Doesn't work
My Acer Aspire has a bluetooth button but it doesn't have bluetooth built in, this is because Acer has lots of different model variations but the exterior looks the same and they use the same hard drive image across the whole model range, this is why I have the software installed but cannot use it as I have no bluetooth device, you can check if you have by right clicking on '(My) Computer' icon then choose manage and then device manager, do you see any bluetooth devices, if not then this is the reason why it's not working.
Jun 02, 2009 | Acer 4220-2346 Notebook
How do I enable bluetooth in my Acer Extensa 4420-5963
Actually Acer use the same laptop case for some of their models, so the acer 4420 doesn´t have built-in bluetooth, you won´t find any driver for the bluetooth cause that reason. I have an extensa 4420-5910, have a bluetooth switch in the case but no bluetooth, if you check at Acer´s web page it say thet some models doesn´t have built-in bluetooth but the switch is in the laptop case... On the other hand, if you install an external bluetooth device, the case switch will be usefull to turn it on and off.
Mar 13, 2009 | Acer Computers & Internet
Acer Aspire 3613 cracks near hinges.
you can lift up the little round circles take out all screws,take top off, to lcd find the little gold nuts that the screws go into, try to put them back in plastic holes with super or gorilla glue,
or order screen parts on ebay, hinges usually get worse unless you find a way to secure those brackets attached to hinges
Mar 13, 2009 | Acer Aspire 3613WLMi Notebook
Cracks near hinge Acer 3613 laptop
Apply a lubricant to the hinges themselves - not a ton of lubricant, as you don't want anything running down into the laptop proper.
What sound like has happened is that the display has somehow been in a bind, and therefore the hinges are in a bind. This makes it harder to moved the hinges, and thus when you open the lid it is making the cracks.
You may also want to unseat / unscrew the hinges and re-tighen the little screws that hold them in place.
Mar 12, 2009 | Acer Aspire 5050-3242 Notebook
Is Acer Aspire 4720z equipped with a built in blue tooth device
The quickest and easiest way i have found is to press the Fn button + the one that turns on your wireless networking if you have one.
But i looked up your system and it says it comes with blue tooth.
"Communications Intel® Wireless WiFi Link 4965AGN network connection supporting 802.11a/b/g/Draft N wireless LAN, Acer® SignalUp technology for enhanced antenna efficiency
or
Intel® PRO/Wireless 3945ABG network connection supporting 802.11a/b/g wireless LAN, WI-FI CERTIFIED™, Acer® SignalUp technology for enhanced antenna efficiency
Bluetooth® 2.0 + EDR (enhanced data rate) wireless PAN (select models only)
Gigabit LAN, Wake-on-LAN ready
V.92 56Kbps* data/fax modem, PTT (postal, telegraph, telephone) certified in select countries, Wake-on-Ring ready
Acer® Video Conference with integrated Acer® Crystal Eye webcam supporting Acer® PrimaLite technology, which consists of a premium sensor, firmware and lenses to provide superior video performance under low-light conditions (select models only) "
I found this here
Feb 27, 2009 | Acer Aspire 4720 Notebook
Acer aspire 3680 bluetooth
I want acer aspier 3680 bluetooth & wireless laptop driver
Jan 18, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3613WLMi Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
