Question about HP Pavilion dv4000 Notebook
Bluetooth Transfer Constntly Fails
Whenever I attempt to transfer photos from mobile phones to my laptop, it fails.
I have paired the devices and set both the phone and laptop to "always visible"
The transfer begins and after a few seconds says "transfer failed"
In the past i have successfully managed to transfer files via bluetooth, each time it would ask me for permission.
When I try now, it does not ask me for permission.
I have encountered this problem with three seperate mobile phones, one of which i have transferred files with successfully.
    President:
  • 2,004 Answers
You must have made the mistake of rejecting a transfer from the phone to PC previously.
I had this problem and the only way is to restore system back to factory setting and dont forget to backup your documents.
rate this fixya
Posted on Apr 12, 2009
My Samsung sdh-r631 phone still works but I no longer have a carrier. how can I upload my vids & pics to my laptop?
If you want to transfer your files from your phone to your laptop you have 3 options.
A. Via Bluetooth
B. Via SD card
C. Via Samsung mobile phone software.
A. Via bluetooth
1. Open your phone bluetooth as well as your laptop
2. Pair them.
??how to pair.
???open your laptop bluetooth
???right click the bluetooth icon in the tray and select add a device.
???select your phone. And select ok.
3. From your laptop bluetooth, right click the icon in the tray and select receive file transfer
4. From your phone, open gallery and select your photos and videos and select share, select bluetooth
5. From your laptop, select accept file transfer
B. Via Sd Card
1. Turn off your phone
2. Remove your sd card
3. Insert it in a adapter
4. Insert the adapter in your sd memory card reader
5. Open my computer, select sd card
6. Select the files and start the copying.
C. Samsung mobile phone softwarem
1. Download the apps to your laptop
2. Install it.
3. Connect your phone via usb cable
4. Once recognized, select back up
5. On settings backup, uncheck everything except videos and photos
6. Start the backup else if you want to backup everything then make sure to check everything.
7. Select apply
8. Start backing up.
There are also some alternatives for samsung syncing software, if you want to check them out, i posted the link below.
I hope the above process will be able to help you.
Good luck.
http://www.apowersoft.com/samsung-kies-alternative.html
Sep 04, 2016 | Samsung Cell Phones
How to move photos from original Moto RAZR to computer - en mass
basicly you need the data cable and the motorola software. you can most likely buy the software at the sametime when you buy the cable from the shop. if not its also available online.
May 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
How do i transfer photo from my cell tomy computer they both use bluetooth
pair cell phone to computer.
Turn on bluetooth in cell phone settings.
May need to set cell phone blue tooth to allow devices to discover it.
Go into computer settings for blue tooth
Search for Devices .
Then once paired.
Look at files in Cell phone.
Should be a share option for files
Then Share via Bluetooth .
Aug 22, 2016 | Alcatel Cell Phones
Transfer of pics from Laptop to Samsung galaxy 2
I think it can be easier with an android assistant, you can transfer or backup text messages, contacts, photos, and other media files like videos, music files.
And which allows you to view them on PC, so you can choose selectively and freely. MobiKin Assistant for Android Windows Version
Mar 24, 2016 | Samsung Cell Phones
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
I have a Motorola W377 phone and I have some
You have several options to choose from. I'm assuming you're using a Windows PC since you did not specifiy.
A. Use your phone to email pictures to your computer
B. Use Bluetooth to wirelessly transfer pictures to your computer
C. Use a direct cable connection to transfer the pictures to your computer
D. Transfer to your photo album online* (Check with provider)
E. Use Facebook or MySpace to transfer images
Option A
Create a new phonebook contact to hold the email address
  1. Open phonebook
  2. Options | Create New Contact | On Phone
  3. First Name = Your Email Address
  4. Fill in the email address field too
  5. Create a new message, insert image into message
  6. Send to the new contact you created
Option B
  1. Turn on Bluetooth on your phone
  2. Under Settings, Look for Bluetooth Link
  3. Choose Setup
  4. Turn Power Setting: ON
  5. Your desktop/laptop must also have Bluetooth
  6. Look in Control Panel for an icon, change settings there
  7. Make it say visible
  8. If your computer doesn't have Bluetooth you can buy a USB Bluetooth
  9. On your cell, after you've setup Bluetooth, go to the picture
  10. Choose Send By Bluetooth
Option C
  1. On your cell, go to Settings
  2. Make sure the USB Link is DATA Connection
  3. Open Windows Explorer to see if phone is displayed under My Computer
Option D
  1. Go to your service providers Website
  2. Check to see if they provide you with a photo album online
  3. Check to see what the procedure for transferring photos
  4. For example, I use T-Mobile and have setup my photo album so I can transfer pictures to a three digit number
Option E
  • Setup MySpace or Facebook to transfer photos
  • Search their help pages for instructions
Mar 12, 2010 | Motorola Computers & Internet
Lost instructions how to pair with my phone
Bluetooth technology is a way to boost your mobility when talking on the go. It similarly provides a wireless network for transferring files and pictures that you have acquired on a mobile device. Enabling and using this function can be beneficial whether for business or for pleasure.
  1. tep 1 Select from the menu "Settings" --> "Connectivity" --> "Bluetooth." This will bring you into the Bluetooth menu function, allowing you to configure your Bluetooth technology. In this menu, you'll find an option to turn Bluetooth on or off. Select "on."
  2. Step 2 Look for devices on the mobile phonemag-glass_10x10.gif that will be compatible with a Bluetooth device. There is a menu option to seek these devices. If a device is listed on the menu, you have the option to pair this device with your mobile phone. To do this you'll need to enter your security password. This is generally created when initially setting up your mobile device.
  3. Step 3 Check for the visibility option. The phone does have an option to either make your bluetooth device visible or invisible to other Bluetooth and mobile devices. It's your decision to remain private or broadcast your signal.
  4. Step 4 Use Bluetooth for data transfer. Once connected, you'll be able to transfer calls to your headset, transfer photos from your cell phone to your computer, transfer photos from your computer to your phone, and transfer files back and forth. Ensure your invisibility when transferring sensitive information to avoid hackers and losing information to other Bluetooth users.
Nov 15, 2009 | Nokia 2760 Cellular Phone
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Sending photos from A968 phone
you can send pictures from A968 china mobile by using the bluetooth facility.You can transfer the photo from A968 china mobile to other mobile or computer by switching the bluetooth "on" in both the mobiles and can pair mobiles and you can transfer photos or any other data
Jan 10, 2009 | Nokia 6300 Cellular Phone
HP Pavilion dv4000 Notebook Logo
221 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
