Question about Electrical Supplies
I get no 110 or 220 volt power
Generac 5000 power plus generator runs the two brushs put out 5-6 volt i dont see a capacitor and only electronics are mounted on brush board 3 or 4 diodes and a litle orange thing all on a 1x1 inch board the brush wires go to
    President:
  • 1,388 Answers
Generac was purchased by Briggs Stratton some years ago, however some information is available at the following web address, just enter your model number:
http://www.generac-portables.com/service_support/owner_manuals/owner_manuals.cfm
The small board that you describe is the bridge rectifier that converts ac from the windings to dc for the armature. You can test the brush/board by removing the part from the generator and applying 12 to 16 volts ac to the input tabs/wires then test/read dc (dc voltage will be lower than input ) voltage at the brushes. Use meter to make sure that you are getting dc. I use a small power supply less than one amp that I purchased at the thrift store for a couple of dollars. If test fails replace part. If it tests ok re-install brushes and re-connect the ac power supply to brush/board which in turn will energize the armature. At this point test the armatrue for magnetic power. I use a thin welding rod or wire against armature. If you feel a magnet start the engine. If the windings are good you should get some voltage at the plugs and the two wires that feed the brushes (will not be full voltage). If voltage is present, kill engine and disconnect ac power supply and connect the original wires to brushes/board and start engine. If you now have voltage at plugs you spiked the system indirectly by energising the armature. If still no voltage you may have an open circuit that feeds the brushes or diode pack is failing with the incresased voltage. Good luck with your repair and email if you have questions.
Posted on Apr 14, 2009
My generac rv generator runs bu no voltage output.
Try putting 12 volts across the commutator at the brushes. Ust a low current battery nor a car storage battery.
Good luck,
Marty
Jul 16, 2014 | Generac 5754 4.8 kW 120/240 Volt PrimePact...
I have a generator that does not produce any volts. I replaced the brush block because it was bad with no help. I took resistance readings of the rotor and stator. Are these in spec?? briggs and stratton...
As long as you have continuity through the stator and rotor windings, and no continuity from the windings to the core, you should be good.
If the brush block was replaced due to it being defective, take a look at the diode and capacitor regulator as well. Using a multimeter, the diode should indicate continuity in one direction, infinite resistance in the other. If you get this, then replace the capacitor. If not, then replace the diode, and likely the capacitor as well.
May 28, 2010 | Briggs & Stratton Electrical Supplies
I get no power 110 or 220v from my generac 5000
The best thing to do at this point is to flash the fields. You do this by applying battery voltage (12Vdc) or 6Vdc to the wire that come from the brushes. The brush closest to the bearing is Positive and the brush near the rotor winding is Negative. While the generator is running apply battery voltage to the correct spots on the brushes. You should see an increase in voltage. If you do see an increase, then you will need that little board with diodes, that is your voltage regulator. Use rubber gloves when performing this procedure and stay away from rotating parts.
Apr 12, 2009 | Electrical Supplies
How do i flash my generac 5000 power plus generator
well I have a special flasher unit but I believe you can put 12 volts to the brushes while it's running. That should do it.
Apr 09, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
No power output from my generac 5000 power plus generator
It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
Apr 09, 2009 | Generac 100 Amp 120/240-Volt Transfer...
No power output from my generac 5000 power plus.
sounds like you need to "flash the field". This means you've lost you excitation voltage for the generator to produce electricity. In most cases you need to get a 9volt battery and connect it to 2 & 6 inside the generator. They are Blue & Red wires, but they are not the only blue & red ones there. The generator should be running and the battery should only be connected for about 5 seconds. This is very dangerous because of all the high voltage and democrats.
Runs great but will not produce electricity
To flash the excitor circuit on a coleman ( the generator is built by generac) you need a 12 volt battery. You quickly apply 12 volts via your 120vac recepticals. NO MORE THAN ONE OR TWO SECONDS! Then check you ac voltage. Most of the time the brushes are burnt up when voltage is low. Check the brushes first. You can access them by taking the end cap off of the generator via two to four screws. The brush holder is easy to spot, two wires leading to the front of the amature. Hope this solves your problem.
Mar 29, 2009 | Coleman Powermate Premium Plus 6250W...
No electrical output
Feb 13, 2009 | Generac Guardian 065795 - battery charger...
Coleman 5000 generater-no AC output
have you conected the brushes on the right way? the leads are + and -.
you can run it up and use a 12v battery and connect it to the brushes correct polarity, with the othe LEADS removed and taped can shock you and chect the out put it it around 100 120v chech the AVR or brush polarity.
If yours dont have brushes it will have a capasitor that is prob out of spec.
Jan 10, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
504 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
