Question about Tally T2250 Matrix Printer
Recover tally data
It lost due to corruption of file
  • 17 more comments
  • vinoo11 Mar 15, 2008
    C:\Tally\data\0008\tr01297.500
  • Anonymous Apr 09, 2008
    my tally comny every 4 to 5 day company corrept this file error every time is diffrat error my no eny virus i have the complate and i havr all ready format and r install os and tally versin is 7.2 and tally 9
  • Anonymous Apr 12, 2008
    data error in tally 7.2
    C:\Tally\Data\0001\Tr01299.500
    Position:56064
    Chars:128(done 128)
    Sushil
    email:sushil@tool-world.com
    ct.sushil@gmail.com
  • Ranjeet Mehta Apr 25, 2008
    Same Problem of my
  • Anonymous Jun 25, 2008
    exiting tally
  • gayu Jul 04, 2008
    My laptop suddenly restarted after which I got error message 'Internal Error' Exiting Tally... I am able to view the datas but not able to load further. What should I do?
  • gayu Jul 04, 2008
    This is Gayathri. I have tried rewriting the company. But nothing is really working out for me. Could somebody please help me out in resolving this issue? It's very urgent.
  • nishantbh Jul 21, 2008
    This is Nishant. I could not open few companies in Tally. Its only showing rewriting process and nothing happens? Please solve this issue.
    nishant.bhanot@gmail.com
  • Anonymous Aug 18, 2008
    when i working on tally 5.44 due to power failure file corrupt . now tally can not open the file . it shows error
  • saurabh_chaw Aug 25, 2008
    hi this is saby,
    i formatted my c: drive bcoz of virus infection, and by mistake i forgot to take the backup.
    but still i recovered my files through "files recovery s/w",
    now the problem is this that, the tally file are damaged or corrupted after recovery, n so i m unable 2 use those files.
    plz give me the solution of how those damaged files could be corrected, plz send it 2 me urgently on my id: saurabh_chawla74@yahoo.com
  • Deepak Sharma
    Deepak Sharma Oct 08, 2008
    hi i m the following msg,, while running tally 7.2
    Exiting TALLY
    Error reading data
    file e:/tally72/data/0006/Tr01302.500
    Position 512
    chars 128 (done O)
    please if anyone have a solution for this,...plz kindly mail me on deepak_8583@yahoo.com either it will be a big loss of data and time..
    please help................
  • Pinyon25 Nov 11, 2008
    Error !
    Exiting Tally !
    File Damaged.
    Fie:'\\Server\Data_Anesta_Agung\0003\Manager.500'
    Position : 443520
    Chars : 128 (done 128)
  • ajaysharma7 Jan 23, 2009
    i have the same problel . pls give the solution
  • Uttam Nakrani Feb 26, 2009
    Error !
    Exiting Tally !
    File Damaged.
    Fie:'\\tally\Data\0003\Manager.500'
    Position : 443520
    how to solutions this problem
    my email unnakrani@yahoo.co.in
    Error !
    Exiting Tally !
    File Damaged.
    Fie:'\tallyData
  • ankit_agrawa May 01, 2009
    Error !
    Exiting Tally !
    File Damaged.
    Position : 443520
    Chars : 128
  • sarat339 May 11, 2010
    hi
    it is same problem
  • Dear Sir/Madam,
    I am getting the following error,
    Existing TALLY file damaged File:D:/Tally72/Data\0009\Tr01341.500
    Position:180224
    Chars:128(done 0)
    Please give me a solution to get my data and I am using Tally7.2 version...
  • Anonymous Mar 21, 2014
    You can try minitool power data recovery ?MiniTool Power Data Recovery contains five data recovery modules - Undelete Recovery, Damaged Partition Recovery, Lost Partition Recovery, Digital Media Recovery and CD & DVD Recovery. Each data recovery module focuses on a different data loss scenario It can recover deleted data from the Windows Recycle Bin, restore lost data, even if the partition is formatted or deleted, restore data from a corrupted hard drive, virus infection, unexpected system shutdown or software failure. It supports IDE, SATA, SCSI, USB hard disk, memory card, USB flash drive, CD/DVD, Blue-Ray Disk and iPod
Dear Sir/Madam,
Existing TALLY file damaged File:C:/Tally/0001/Tr01298.500
Position:149760
Chars:128(done 128)
Thanks & Regards,
S.Prasada Rao
Posted on Sep 28, 2008
Exiting Tally !
File Damaged.
Position : 443520
Posted on Mar 14, 2009
  • 3 Answers
Hi I am Amar Kamedia From Indore
My Data Loss In Tally 7.2 in last day how to Recover My Data
Sales Register To Close Tally Application in May Month
Exiting Tally!
File: "D:\Tally\Data\0001|Tr01300.500'
Position: 688128
Chars: 128(done 0).
Posted on Jun 08, 2008
1.write the filename along with address path from the error message and exit tally
1. go to the program source directory where tally72.exe is located
2. open 'tally configuration settings' file & check the data where the companies are stored
3.go to that location where companies are stored, now locate the folder containing the corrupted file.
4. move (cut-paste ctrl-x) that folder to some another location
5. now start tally7.2
6. go to select company switch to tally comapnies folder
7. restore now the moved folder to its original location and switch to tally
8. now press Ctrl-Alt-R
9. press Y for rewrite
10. you will get your desired company
- Shriprasad Marathe
Posted on Jul 11, 2008
  • rajesh_41380 Oct 04, 2010
    Thanks alot.Now its running smoothly
My date error
Posted on Sep 20, 2008
  • yashraj13 Sep 20, 2008
    Tally 7.2 Showing Message at starting on particular company
    Fil damaged
    position 83968
    chars 128 (done 128)
    please help me to solve the problem
    E-Mail : yash17@in.com
Fil damaged
position 83968
email: vijay2233@gmail.com
Posted on Mar 14, 2008
Posted on Mar 15, 2008
Sir whil clicking the tally9 . it display the data corrupted ,run the virus check and reinstall the application
Posted on Mar 03, 2009
Sir this is nagappan and i unable to use multi printing in tally 9 release 1. please help me .
since i am not familar with this 9 can i convert the data back to 7.2 or 5.4 pl help me.
my mail id is vimala_nagappan@yahoo.com
Posted on Jul 22, 2008
Hi myself rajesh sharma i hv tallyerp9 on auto backup but i hv faced problem while restoring data.the message shows data restoring failed plz if any solution plz contack 9872528016 or smannu82@gmail.com
Posted on Aug 25, 2012
How to recover a damaged file in tally
Posted on Aug 15, 2012
Exiting tally error,file not found,Attempting to open D:\tally\data\0013\manager.500
Posted on May 15, 2010
Tally Data Repair Indore Call : 9827164209 mail id n_ilu64@rediffmail.com Hardware & Networking Solutions Indore Tally 4.5, 5.4, 6.3, 7.2, 9, ERP For any Solution of Tally Data, Troubleshooting, Password Recovery,Network ...
Posted on Mar 19, 2010
I am unable to retrieve data on tally.It is showing a message that
chars:128(done0). plz give solution to this.
Posted on Jan 08, 2010
Fil damaged
position 83968
E mail arasu_dmdk@yahoo.co.in
Posted on Sep 22, 2008
  • vishupandit3 Nov 26, 2010
    send me the file i will repair the file for you
    vishupandit2004@yahoo.com
    Mobile No:-09755559560
Hi i am Ashwin Gujarathi
While selecting the company Tally 7.2 close with the massage -
Existing Tally!
File : D\Tally\Data\0013\Tr01298.500'
Position 13312
Chars:128(done 0).
What can i do for recovery plz suggest me on my ID
email ID : - ashwingujarathi@rediffmail.com
hit.4314@gmail.com
ashwin.gujarathi5@gmail.com
Thanks
Ashwin
Posted on Jul 29, 2008
My tally7.2 data damage pl help recovery solution my id
maxxy_bill@rediffmail.com
Posted on Jun 17, 2008
Dear,
I using tally 7.2 . I enter for tally sales register for D A S. than i enter for last month oct 2008 sales reg. not open. i have try re-write but problem is not solve. pls recover my tally data .
thanks
Harpreet singh
Posted on Oct 16, 2008
HI ,
I AM TALY EXPERT , IF YOU CAN PROBLEM IN TALLY PLS SEND ME YOUR DATA FOLDER ON MY E-MAIL ID
nns232000@yahoo.com
Posted on Oct 10, 2008
3 Suggested Answers
SOURCE: Tally Data Recover
Here is a solution for your problem, simply use the inbuilt tally recovery tool as described here - http://www.megaleecher.net/Tally_Software
Posted on Jul 12, 2008
SOURCE: tally corrupted file
well i solved this problem by ff method :
on the main screen i presses ctrl + alt + R
then selected the corrupted file to recover
Posted on Jun 22, 2008
My computer due to power failureand when i restarted it again my tally 7.2 showed this message ....
It is your computer, showing something went wrong (serious wrong) with the Tally program. It is even telling where to look. But you should look it up on the Megaleecher website.
Recover Corrupted Tally Accounting Data
Oct 10, 2014 | Office Equipment & Supplies
Tally data recover
if u have tally software which is ur instaled in your computer. again install the previous operating system in other drive like "D" & "E". then recover the drive "C" by using "recuva recovery software". then find the your tally files and save it in another place like "DVD" disk.
then install your tally software and use it . all the best my frnd.
Nov 24, 2013 | Microsoft Windows XP Home Edition
How can i recover a corrupted word document (.docx) file?
If you cannot find any of your Word, Excel, PPT or other Office files on your Mac, you might have met file loss situation. But don't lose your hope. Here comes an amazing solutions for Mac deleted Recovery to help.uFlysoft Mac Data Recovery Tool can help you to recover the lost files on your Mac, It is a professional Mac data recovery software which is powerful enough to retrieve unsaved, corrupted and deleted Word files easily.
Nov 03, 2010 | Microsoft Computers & Internet
Os Windows Vista Home basic Tally 7.2 when opened, opens and closes immediately showing message Tally 7.2.Exe has stopped working What could be the problem
It may be due to some tally related system file might have got corrupted.
You can rectify the problem by reinstalling tally software as this will fix the corrupt files. but before that copy the data folder to a safe location to backup your tally data.
i hope this is helpful to you
Thanks
Jul 29, 2010 | Computers & Internet
I m uing tally 7.2 rel.3 beta version... i lost my company data from pandrive.. i got it back after recovering it.. but when i pur it into the data folder and open tally 7.2 i could not see my company in...
Usually the recoverable data from a deleted or formated hard drive or a pen drive does not work, only the wallpapers and text files work completely other files of 5mb 10mb like exe, video or any data files does not work because they become corrupted. Therefore your software can't recognize your data because they are internally corrupted. So, there is no way to recover 100% correct files. But you must try to recover data using
"Recover My Files" software or "Virtual Lab"..but chances r very less.
Good Luck
I hope your data will recover.
Nov 25, 2009 | Computers & Internet
How to recover delete tally data
I accidentally deleted some valuable information on tally 9, how do i recover the data?
Jul 10, 2009 | Computers & Internet
Tally corrupted file
My tally 7.2 files are corrupted due to power failure
Tell me how can I repair these files
Jun 21, 2008 | Tally T2250 Matrix Printer
Tally6.3
Sir,
There is no option to recover the password. But there is simple steps to recovor the data... try it
Lets understand some feature and working of tally. Tally provides a backup and restore utility which collects all files of tally company into one file named tbk500.001. This way of tally backup is easier to restore as this one file can be kept save and easily can be restored instead of all files in that folder. If any of the file gets missing or gets corrupted tally data wouldn't work.
In first case when data gets corrupted while working on tally and we are unable to open the company then data can simply rewritten. Come to Company selection menu. Press "Ctrl + Alt + R". Now select the company for re writing. 90% chance is that you problem would be get solved.
This is the best website for all the tally solutions. try it
http://www.apnitally.com/2006/09/recover-your-data-in-tally-some-tips.html
Thanks
Good Luck
“Don’t Forget to rate the Solution”
Jun 14, 2008 | Computers & Internet
Tally Data Recover
Jun 08, 2008 | Tally T2250 Matrix Printer
Tally T2250 Matrix Printer Logo
14,172 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
